Low mount turbo oil skavenging system
Old 07-17-2017, 07:56 AM
Fritz Wehring's Avatar
Default Low mount turbo oil skavenging system
What is everybody using for a skavenger pump and oil return system on twin bb turbos?
Old 07-17-2017, 02:46 PM
Game ova's Avatar
Base turbowerx here. Just a line from the drain to the pump.... to the oil pan.
Old 07-17-2017, 04:57 PM
stevieturbo's Avatar
Turbowerx Exa.
Old 07-18-2017, 12:13 PM
jksstar's Avatar
I use a shuflow , been on the car for a year now
Old 07-18-2017, 03:45 PM
EarlH's Avatar
Custom Tank and Turbowerx Exa
Old 07-19-2017, 02:28 PM
AlexLSx7's Avatar
Turbowerx Exa
Old 07-19-2017, 04:17 PM
ls13ater's Avatar
If it's a f body buy the on 3 raditor and have Somone move the turbo up, scavenging works but when you start burning Relays and piping fuses it becomes a head ace
Old 07-20-2017, 01:55 AM
AlexLSx7's Avatar
surely you have an electrical issue somewhere causing that? And if not, put the relay and fuse in an easy to get to location. Would take me 2 minutes to change both my fuse and relay for the pump.
Old 07-20-2017, 02:03 AM
Game ova's Avatar
A relay is not necessary for a scavenge pump. Just wire it into the accessory port in the fuse box, it's only live when the key is on. Doesn't really make sense to have it on a switch.
Old 07-20-2017, 02:21 AM
AlexLSx7's Avatar
I have a relay on mine so it comes in with the fuel pumps and turns off with them. I don't have an fbody I have an Rx7
Old 07-20-2017, 02:59 AM
Then you're doing something extremely wrong.
3 years on and I've never blown a fuse or relay. Whilst they do only draw around 5-6A, I would still say to use a relay.
You shouldnt be blowing any fuses no more than your lights should, fuel pump, radio...or any other circuit in the car.
Old 07-21-2017, 08:51 PM
Taxman20's Avatar
I run a RBRacing pump. Relay on a switch.
Old 07-21-2017, 09:33 PM
ls13ater's Avatar
Same way I have it on a friend car, but it's Starting to have issue
Old 07-21-2017, 09:39 PM
ls13ater's Avatar
Then you're doing something extremely ls.
Not on my car it's on a friend f body with a a/c Huron kit, my car has the turbo mounted high enough to not need one, his has worked great for over a year until recently it blowed a fuse, replace it, all was good for a month or 2 then he took a trip and the relay went bad I had to walk him threw the steps on bypassing it, but it will be getting moved up soon he tired of hearing the pump run also
Old 07-21-2017, 11:13 PM
jchevy's Avatar
Which shurflow are you using?
Old 07-22-2017, 04:57 AM
What pump is he using that he can hear it ?
The Exa is very quiet, no chance of hearing it over the engine
Old 07-22-2017, 07:03 AM
Game ova's Avatar
Either he has the world's quietest car..... or his pump is screwed.
Old 07-22-2017, 08:08 AM
ls13ater's Avatar
Nope his is a gear driven style pump like the one on the right in this video
Old 07-27-2017, 07:15 AM
jksstar's Avatar
Hell I got it along time ago, Id have to look. I think it was the same one Zombie on here is using
Old 09-30-2017, 04:18 PM
BoostForBreakfast's Avatar
I originally used an ebay scavenge pump. Loud as hell and couldnt prime well in the location i needed it. This is on very low mount twin holsets. Swapped to a base turbowerx and much, much quieter, and so far so good
Quick Reply: Low mount turbo oil skavenging system
