Project Hairy Banana (1967 Camaro single turbo)
#262
LS1Tech Co-Founder
I know this came up before, but I don't understand how the alternator gets wired up.
One of you guys mentioned this pigtail:
https://www.summitracing.com/parts/hly-197-400?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-holley&gclid=EAIaIQobChMIw-Oi0_3k2gIVFweGCh3a4AwYEAQYASABEgKclvD_BwE
EDIT: M Minnick shared that it gets run to switched power.
#263
That pigtail says it has the resistor in it so it will work. Basically an Alt wont charge unless it gets a little juice fed into it first but not too much or it damages it. So the old school way was to run a 12volt ign+ feed directly to the alt with a tail light bulb wired in so the circuit wouldnt short, but enough flow remained to excite the alt so it would charge ( think test light ). Then someone got smaerter and started using a resistor. IIRC the charging light in the dash is used for this purpose in older OEM vehicles. I dunno though its many years back so what I do know is you want to run a positive voltage ign feed directly to that pin on the plug on your alt with a resistor soldered inline and it works mint. Or buy that pigtail and go
Hope that makes sense, i think it confuses me further LOL jk
#264
I know I posted this before but here it goes again lol..... buy Holley pig tail and wire a 12v keyed hot to that wire.... then run a heavy wire (like 2 gauge or bigger) from the stud on the rear of the alt to your shut off switch (which I’m guessing you will be running)....
#265
LS1Tech Co-Founder
^^^Thx guys (and 47ford that was you who posted it before I know hehe), I get it now.
I'll order the pigtail and get that going next week.
I need to start thinking about how to mount the computer.
#266
Trust me I read thread after thread until my eyes were crossed because you can’t believe everything you see on here. That’s the way I did it and volts are perfect under load and idle and has been like that for a while. I wouldn’t steer a fellow 1st gen owner wrong lol
#268
LS1Tech Co-Founder
Getting great advice on mounting the computer, relays, fuses, thanks Mike M and Pete L. I am going to find to find a board preferably carbon fiber. Would make it easier to mock it up all up before it goes up under the dash.
This week I will:
What is the go to wire loom that folks are using? The plastic crinkle stuff I used in the 90's must be outdated by now?
This week I will:
- Install harnesses as they show up (front lights, rear lights, in-dash for them, all OEM stuff)
- install alternator pigtail, I guess use a resistor I read 420 OHM
- Buy/ source CF board or aluminum?
- Most likely take my current fuse board and reuse it, why by another. The wires are so long I guess I should take it apart?
#269
LS1Tech Co-Founder
Happy Saturday...
Earlier this week all the harnesses came in:
The front harness is easy to install.
But then I ran into an issue, I did not know how the stock harnesses mated to each other. So I asked a FB first gen group for a pic:
- Front harness, headlights mostly
- Rear harness, taillights
- In-dash harness
#270
LS1Tech Co-Founder
Pic of my setup. I'm like 'oh crap' someone butchered mine all up. Kinda bothered me. I ate dinner, took a showere, but I was dying to know how bad it was.. Went back out.
Hmmm, the patch is held in by bolts, let's see:
....And the factory hole is intact!!
#271
LS1Tech Co-Founder
Anyway, first day it's not raining out, so I'll get back out there in half hour and install the in-dash harness and the rear harness.
Big items left for me to procure:
-Strange Rear brakes (buying used with 30 passes from buddy)
-Electric fans, I like Doug Cook's Derale setup, getting same one. Overkill but I will street drive in Chicago Cubs traffic sometimes.
-Fuel line fittings. I need to sit down with my buddy Anthony Manna to diagram out the system, and figure out what to order.
I have been talking to a guy who wired his single turbo LS Nova, might be using him to make the board.
#272
LS1Tech Co-Founder
- Front OEM headlight harness installed
- In-dash main harness installed
- Rear taillight harness, used, had issues, another harness on it's way
- Ordering front shocks today
- Installing front Strange brakes and hopefully Viking double adjustables this weekend, and rear harness
Future:
- Need to swing by buddy and pick up used Strange brakes with 5 passes on them
- Going to order fuel line soon
- Talking to new friend about building me a wiring board. Worst case I will do it myself.
#274
Lead.
#275
LS1Tech Co-Founder
Interesting... I don't plan to take it all apart to paint it. But I'd like to coat the manifolds and maybe other parts of the turbo kit.
As for the body paint, I'm indifferent. I'm more about going fast in this car than trying to mint out a quasi race car. If wraps weren't 3k I'd wrap it.
#276
Lookin good! Harness wrap I like that efi connection stuff I mentioned earlier. Its tough and looks good, heat resistant, OEM rated blah blah blah. You book marked it me thinks
Anyways the board? CF strictly because no conductivity. I dont think i missed any other question i can answer. Keep after it this is getting good now
