Project Hairy Banana (1967 Camaro single turbo)
Old 10-29-2018, 10:29 AM
  #421
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
More boxes showing up, the remainder of the wiring stuff I need.
Buying a garage heater, planning to crank out more stuff this weekend.
Old 10-29-2018, 10:36 AM
  #422
cam
cam's Avatar
Nice! I predict first start before Christmas. One thing about working in the cold, it sure motivates you to keep moving so usually more gets done. Twisting wires can be tricky with numb fingers though, way to keep after it
Old 10-29-2018, 11:31 AM
  #423
TXsilverado's Avatar
keep up the progress. I got some miles in on the ol 69 over the weekend and made some progress of my own. The Holley dash is installed, and the interior is back together. still need to bolt the seats down...they're just thrown in the floor for now. on to the meth injection install. almost ready to send those wiring pictures that you requested.
Old 10-30-2018, 07:40 PM
  #424
LS1Tech Co-Founder
I need someone to yell at me so I will become brave and swap the front control arms and do the brake lines....
Old 10-30-2018, 08:49 PM
  #425
3pedals's Avatar
"brave"???
it's just bolts dude,
Get r done
Old 10-30-2018, 09:08 PM
  #426
cam
cam's Avatar
Get in there! One bolt at a time, use torque wrench, be careful with suspension spring. Done
Repeat side two
Run lines, bolt up, call wife to help bleed or one of the young lads. Yell to pump pedal, hold, release bleeder, tighten, yell pump/hold repeat til firm. Must yell though, manly man yell
Old 10-30-2018, 09:56 PM
  #427
LS1Tech Co-Founder
Thank you (mean) friends.
I ordered new bolts for the arms, one less thing to worry about. I do know how to deal with the springs, I've seen the jack and crow bar method.
Old 10-30-2018, 10:03 PM
  #428
cam
cam's Avatar
Good your clued in on the springs. Just give the side of the control arm where it surrounds the ball joint a good smack with the BFH or three and it should release pretty easy. If not I like to use heat on the spindle and then soak the hell out of it with PB blaster which will wick up into the taper then another smack with the bfh and you should be good to go!
Hoo yah
Old 10-30-2018, 10:24 PM
  #429
orange88ls1s-dime's Avatar
Leave the ball joint hooked up
floor jack under control arm
undo lower control arms bolts and lower shock
let floor jack down
remove spring
remove control arm (if replacing)
use this method to reinstall spring as well
if anything shifts during process spring will not get to you as you will be protected by spindle assembly
I use this method all the time with no issues
works on modified McPherson strut as well (third gen camaro and fox mustang)
Old 10-31-2018, 05:49 PM
  #430
Hellsx's Avatar
What i do when dropping coil springs, i pass a chain thru the springs coils as well as thru center of the Arm. Keep chain tight looped to the Arm with an adjustable chain link, keeps coil from ever flying out. Drop the Arm, when pressure is off the coil, slack chain and remove. ��
Old 11-01-2018, 08:53 AM
  #431
LS1Tech Co-Founder
Chain is a good idea, got one of those lying around.
Old 11-01-2018, 09:18 AM
  #432
408GT's Avatar
I've used two small ratchet straps before to compress the spring. Worked much better than a spring compressor and fairly easy to remove after install. I've tried the remove the control arm method too and it works ok, but it can start lifting the car if not enough weight in the car.
Old 11-01-2018, 07:59 PM
  #433
Forgot to mention
if the jack does start to lift the car when putting the lower control bolts back in then you can put a ratchet strap from the front axle of the jack to a hole in the subframe of the vehicle
Old 11-03-2018, 09:52 PM
  #434
LS1Tech Co-Founder
Got one side done, took probably 3 times longer than what folks would say it takes to do both.. hehe
Old 11-04-2018, 06:51 AM
  #435
cam
cam's Avatar
Old 11-04-2018, 06:52 PM
  #436
Ratical's Avatar
Were they factory springs John or Moroso trick springs? The factory ones are fairly easy to change but those damn trick springs are so long they are a bitch to get in on my car. I went with coil overs now and a ton easier to do.
Old 11-05-2018, 08:50 AM
  #437
LS1Tech Co-Founder
Stock V6 springs, I cut one coil. Still sits high. A few folks on FB think I should loosen bolts and then see if it settles. I can push on it and get it to move 2-3 inches up and down so I don't think it's bound up. Another knowledgeable 1st gen buddy/racer said it will probably settle another 1.5" inches...
So I'm thinking I'll cut one more coil when I get free time.
Old 11-05-2018, 08:51 AM
  #438
LS1Tech Co-Founder
Old 11-05-2018, 09:04 AM
  #439
dmracing's Avatar
I’d wait to see where it settles at
Old 11-05-2018, 09:36 AM
  #440
LS1Tech Co-Founder
NO!
Okay I will.
Quick Reply: Project Hairy Banana (1967 Camaro single turbo)
