LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Corvettes and Holley ECU's (https://ls1tech.com/forums/forced-induction/1876884-corvettes-holley-ecus.html)
oscs Aug 2, 2017 03:32 PM
1 Attachment(s)
Sooooo i picked up a nice 02' C5Z for cheap and im considering going full retard. I've been reading on the vette forums about integrating it and im getting mixed responses about whether factory options can be kept. I don't care about traction control but id pretty much like to keep everything else. Anyone here have any first hand experience?
1nverted Aug 2, 2017 04:47 PM
im curious to know as well.. im assuming its possible but a wiring headache piggy backing one system to another, one thing you will def have to do is bumper exit though
C5_Pete Aug 2, 2017 05:14 PM
Piggybacking a holley onto the OEM pcm has been done quite a bit. While it's not necessarily hard, it does take patience.
I've not done it but a friend has done a couple of them. You get to keep most everything, as the Holley runs the engine, the pcm/bcm controls the car.
Have fun with your new project!
oscs Aug 9, 2017 01:03 PM
:punch:
oscs Aug 9, 2017 01:04 PM
Thanks man. Is he on here? Id love to pick his brain.
C5_Pete Aug 9, 2017 01:24 PM
I do not believe he's on here. I'll send him a text.
SLOW SEDAN Aug 9, 2017 02:12 PM
Certainly possible with a Dominator, but you will have some hours in wiring!
Not sure what you are looking to keep? Cruise control, A/C, ABS? I can see those being fun! haha
oscs Aug 9, 2017 02:46 PM
Its going to be a bitch i know... BUT i want to keep all of the above. The only thing im willing to sacrifice is the traction control.
Thanks man
dburt86 Aug 9, 2017 03:19 PM
fueltech told me they have a plug specifically for full integration into CTSv's and i thought vettes. They told me they have full function.
Thats all i know.
stevieturbo Aug 10, 2017 05:50 PM
The less you integrate the ecu, the easier that will be.
So OEM ecu will still need to run the throttle and as much as possible as it did before with all wiring remaining intact. So you will end up tuning on two fronts to a certain degree both the OEM ecu and Holley.
Many sensors can be shared...2 wire sensors like air temp, coolant temp cannot be shared unless you can turn off any internal pullups within the Holley...which is probably very unlikely.
Either way, safest to run a sensor for each ecu.
Likes of crank, cam, MAP etc, 3 wire powered sensors, there should be no issue sharing the same signal with both ecus
If doing a piggyback, it can be handy to try and source a male/female connector set for the ecu, so you can actually make a patch harness to just plug in, rather than starting to cut factory wiring. Makes stuff a bit easier and neater to change, especially if you wanted to go back to the OEM stuff without leaving a mess behind.
hellbents-10 Aug 14, 2017 03:48 PM
If looking to stay at or under 1000hp I would not bother.
Blown06 Aug 18, 2017 02:05 AM
I'm gonna agree with this. It really isn't worth the trouble if not looking for an all out max build. If you wan't an all out max build, do what I did and rewire the car from scratch so you can keep your power windows and shit like that.
C5_Pete Aug 18, 2017 10:20 AM
What relays did you use for your power windows?
Detoxx03 Aug 18, 2017 01:08 PM
I'll agree with these guys
SLOW SEDAN Aug 18, 2017 01:53 PM
Not sure what he used but these made my life much easier for wiring the power windows.
http://www.watsons-streetworks.com/i...le-450x450.jpg
http://www.watsons-streetworks.com/p...versing-module
Blown06 Sep 1, 2017 01:54 AM
No need for a relay to make the windows work. Google "reverse polarity" and "Double Pole Double Throw Switch". Easy as pie.
SLOW SEDAN Sep 1, 2017 06:43 AM
lol I did, but my switch panel had already arrived with a labeled rocker switch so I had to make it work.
zapp109 Sep 1, 2017 08:13 AM
You can have traction control setup through the Holley. I run it on my dominator. The only reason I'd piggyback a factory harness would be to try to get through emissions. Pain in the ass and that's why I didn't do it on my wife's 01ss. Holley can see about anything you want it to see and control. Dominator has tons of input outputs. So if you want to keep a/c no problem Holley can adjust for a/c.
Blown06 Sep 3, 2017 12:42 AM
I don't want to get too far off track here, but aren't the door releases electronic on these newer vettes? It's little things like that, that make me wonder...
© 2026 MH Sub I, LLC dba Internet Brands
