5.3 T56 S480 Dyno results
Old 08-04-2017, 11:13 AM
ezzlez28's Avatar
Default 5.3 T56 S480 Dyno results
After about 8 months I finally completed my build. Going from a stock bottom end LS1 on nitrous to a single turbo 5.3.
Gen 3 5.3 iron block, bored to 3.800.
Wiseco pistons
K1 Crank
Lunati billet rods
Trickflow 220 as cast
BTR stage 3 turbo cam
FI S480, T6 1.32 A/R, billet wheel, stock cover
Holley single plane
Holley 120lb injectors
Chrs1313 twin 450 drop in
McLeod Street Twin (heavier springs, different material)
Holley Dominator (Dual solenoid, Co2 boost control)
Custom turbo kit by Big 3 Racing (2.25 crossover, twin Precision 46mm gates, Treadstone TR1260 intercooler, Precision 64mm BOV)
On 93/meth we ended up making 850/677 on 16 pounds on the third pull. That was my exact goal so we didnt even bother pushing it.
Drained the fuel out, and put in C16. We ended up at 24 pounds of boost, and it made 1051/901 at the wheels. Car ended up making more power on less boost than we expected, and it made a lot more torque than I thought it would. Cannot wait to get behind the wheel again and see where how it does. Just hope the T56 lasts until Winter.
Old 08-04-2017, 11:47 AM
2muchboostNY's Avatar
Nice results bud! Any work done to that T56? I cant see the pictures but when does your powerband kick in/start?
Old 08-04-2017, 12:22 PM
LS1Tech Sponsor
TrickFlowTech's Avatar
Nice work!
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 08-04-2017, 12:34 PM
svslow's Avatar
How much timing on 24psi?
Old 08-04-2017, 12:43 PM
ezzlez28's Avatar
Its a "stage 2" T56 from DGCustomz on here. Also has the spray bar/bungs to keep fluid on the gearset. Not sure how the stock gearset is going to like the new power.
ezzlez28's Avatar
17.1 degrees at peak.
15 degrees on the pump gas & meth tune.
Old 08-04-2017, 12:51 PM
SLOW SEDAN's Avatar
Nice results! I love what these little engines can dish out.
Old 08-04-2017, 12:54 PM
svslow's Avatar
Very impressive numbers. What RPM did you turn it to?
Old 08-04-2017, 12:57 PM
HCI2000SS's Avatar
That's awesome! I didnt realize C16 was that much better than 93 and meth. Thats a huge difference
Old 08-04-2017, 02:44 PM
LLLosingit's Avatar
Umm he also upped the boost
"On 93/meth we ended up making 850/677 on 16 pounds"
"put in C16. We ended up at 24 pounds of boost, and it made 1051/901"
Old 08-04-2017, 02:56 PM
HCI2000SS's Avatar
Right that's what im saying. You were able to get more aggressive with the tune with C16 and make more more boost and power. Is that correct?
Old 08-05-2017, 12:20 PM
Nathaninwa's Avatar
Great results. Which s480 is it? T6 and cast or?
Old 08-05-2017, 01:19 PM
cbra-klla's Avatar
What heads??
Old 08-05-2017, 01:57 PM
Nitroused383's Avatar
Originally Posted by cbra-klla
What heads??
Wiseco pistons
K1 Crank
Lunati billet rods
Holley single plane
C'mon guys Nice results !
Old 08-05-2017, 03:42 PM
Nathaninwa's Avatar
Ha, how did I miss that! Even won't over it twice. I'll blame it on a late Friday night
Edit, on that note, I've seen impressive gains with the borg warner V2 race cover
Old 08-07-2017, 09:17 AM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Ain't nobody got time to read...c'mon now...
Andrew
Old 08-07-2017, 11:14 AM
ezzlez28's Avatar
Yeah I fell into this one from a local guy for 850 bucks since he was going to a S488. Couldn't beat it, was basically new. I was considering going to a race cover, and maybe an S484 depending on the power the car ended up making. But this is perfect for now. Put about 200 miles on it since the dyno tune. Little hiccup on the 2-step, but no overheating, IATs are great. Just a ton of fun.
Old 08-08-2017, 06:40 AM
1bdbrd's Avatar
How do you have your downpipe routed? I am assuming out the bumper on the passenger side?
Old 08-08-2017, 07:48 AM
ezzlez28's Avatar
Yea its 5 inch reduced to 4 inch, then out the passenger side.
Old 08-08-2017, 09:59 AM
Gabbiani's Avatar
Got a pic of the graph? How is the spool time?
Quick Reply: 5.3 T56 S480 Dyno results
