CSF 2 Row Aluminum Core Size: 12 1/2" x 28 1/4" x 2 1/16" enough for turbo LQ4?
I was running stock radiator with two derale fans on my old set up(lm7 turbo). The car ran fine unless its 100+ out and then it would get too hot(not overheating but hot enough that i would drive like a granny) AC was broken but everthing was still there.
This time new project and it came with
CSF 2 Row radiator here are the specs.
Aluminum Tank Size: 26" x 2 3/4" (Inlet) , 26" x 2 3/4" (Outlet)
with ford taurus 2 speed fan
This time how ever im using all iron lq4.
I would like to know if a radiator that size would cool a turbo LQ4 at about 600whp
With AC,
Car came with the radiator as parts/not mounted so if i could use it great.
Car is a swap so i would be making new mounts and would rather not have to do it twice if this is too small.
With AC,
