Well she's to get tuned
Old 09-12-2017, 03:57 PM
ls72nova's Avatar
Default Well she's to get tuned
Hopefully the numbers will be good, I'm kind of proud of myself for getting this all done by my own blood sweat and beers. Here's hoping she makes my goals
Attached Thumbnails Well she's to get tuned-photo840.jpg   Well she's to get tuned-photo505.jpg
Old 09-12-2017, 03:58 PM
AnotherWs6's Avatar
Good luck, nice work.
That intercooler is a bit high, no? Can you put a hood on that thing?
Old 09-12-2017, 04:20 PM
ls72nova's Avatar
Good fits with about a half inch to spare on the very front edge. I put it as high as I could to get decent air to the radiator.
Old 09-12-2017, 04:31 PM
svslow's Avatar
Are those the On3 61s?
Old 09-12-2017, 05:25 PM
ls72nova's Avatar
They are the ON3 61mm's in hoping the build boost quick. I'm new to this whole turbo LS thing
Old 09-12-2017, 05:26 PM
3 window's Avatar
What are the goals? Looks good man. Driver's side downpipe outside the frame rail then back inboard?
Old 09-12-2017, 05:30 PM
ls72nova's Avatar
They both dump out under the back of the front fenders for now. Eventually I do want everything tucked up under the car and out the back. My welding "skills" aren't the best to be able to do that right now, with practice I should be able to get it don't down the road.
My goal is 600 plus to the tire. It's a stock 6.0 with a BTR stage 2 cam
Old 09-12-2017, 05:42 PM
3 window's Avatar
You'll make that no sweat. Boosted LS FTW! It's addicting big time.
Old 09-12-2017, 06:08 PM
ls72nova's Avatar
Very addicting, I exploded the trans behind the big block and decided to change the motor trans and rear end. Lol
Old 09-12-2017, 07:09 PM
rkupon1's Avatar
Looks awesum. Im so looking forward to wiring mine n gettn Holley system installed to run it.Turbo LS novas ftw!
Old 09-12-2017, 07:30 PM
Cwarta's Avatar
Good luck! Can't wait to see!
Old 09-12-2017, 07:41 PM
3 window's Avatar
Turbo Novas FTW
Old 09-12-2017, 08:57 PM
jasonsnova's Avatar
Originally Posted by 3 window
Turbo Novas FTW
this^.
600 shouldn't be a issue!
Old 09-13-2017, 05:11 AM
ls72nova's Avatar
I'll let you all know how she does on the 25th. I'm taking her up to complete street performance in PA for the tune
Old 09-13-2017, 06:29 AM
forcd ind's Avatar
Cool-how tight was the down pipe on the drivers side, what size-I was thinking of trying twins on my new build, but with the manifold, steering, etc, looked like it could be tight.
Old 09-13-2017, 07:07 AM
svslow's Avatar
Should be a very responsive set up. A guy on Yellow Bullet made close to a 1000whp with those turbos on a 6.0L not long ago.
Old 09-13-2017, 07:33 AM
ls72nova's Avatar
I ran the exhaust right up to the frame rail and out under the back of the front fender. I can steer with out hitting it. The set up will change later on, I'd like to eventually make full exhaust.
I'm only going to run 93 octane for now and what ever boost the tuner says I can do
ls72nova's Avatar
It has 3" down pipes. The plans are to put a rack in it later to make a little room and feed the exhaust back under the car later
Old 09-13-2017, 07:42 AM
ls72nova's Avatar
Here's some pics when I was building it
Old 09-13-2017, 08:11 AM
ls72nova's Avatar
And another
Quick Reply: Well she's to get tuned
