"How Original".......Billet S480 Fox Body
Old 01-23-2018, 06:31 AM
  #81
svslow's Avatar
You had to one-up me and get the red compressor? Dang
Old 01-24-2018, 11:48 AM
  #82
Lawhead's Avatar
Didn’t even know it was coming with one honestly lmao wait till you see my next post....
Old 01-24-2018, 11:50 AM
  #83
Lawhead's Avatar
Overall I really like how the On3 kit mocked up with even a S400 Chassis turbo, Hood just BARLEY doesn't clear to the point where it won't take much at all the hood pin hole is about 3/4 exposed so talking 1/8th of an inch and were in there. All I plan on doing is either getting a extension type deal so I can use a coupler or may just have that one cold side pipe modded to bolt on with the V-band.
But did find this
The Previous owner of this car just leaves me with surprise after surprise. Looks like he didn't want to swap a set of 50 dollar heads and decided to just JB weld off his failed attempt at getting an exhaust bolt out
Old 01-24-2018, 12:25 PM
  #84
svslow's Avatar
What are you going to do for a downpipe?
Old 01-24-2018, 01:14 PM
  #85
Lawhead's Avatar
Think I'm going to either 90 it before the Strut tower or go out straight and wrap around the strut tower on the back side
Likely before
Old 01-24-2018, 02:01 PM
  #86
408GT's Avatar
I have my turbo (S480) in a similar location as yours, and I sleeved the strut tower and ran 5" as far as I could off the turbo.
Old 01-24-2018, 02:58 PM
  #87
Lawhead's Avatar
Kit had an S400 chassis turbo on it before with a custom down pipe may just run that and run all my fuel on the drivers side
Old 01-24-2018, 03:26 PM
  #88
408GT's Avatar
So you bought the On3 kit from that LTD 93Hatch had?
Old 01-24-2018, 03:36 PM
  #89
Lawhead's Avatar
I bought it from the person he sold the car too I'm pretty sure is how it went down
Old 01-31-2018, 10:23 AM
  #90
Lawhead's Avatar
Here's the pump set up with the Y and everything mocked up, Question is on filters pre pump I have 2 outlets on my cell so the way I'm going to do it is feed both pumps with their own feed from the cell, I plan on running the diesel type fuel filter post pumps but was curious as to what you guys would run pre pumps with these AEM 380's that isn't going to be restrictive
Old 01-31-2018, 10:36 AM
  #91
roastin240's Avatar
Run an aftermarket 100 micron inline filter on each inlet of the pump.
Or use another one of those Y fittings and a single large 100 micron fuel filter.
Old 01-31-2018, 10:55 AM
  #92
Lawhead's Avatar
Only thing about these Y's is the take up a lot of space and would have to go down from a -10 inlet on each pump to a -8 inlet as these Y's aren't made for a dual 10's inlets to single 10 outlet.
Old 01-31-2018, 12:30 PM
  #93
roastin240's Avatar
Run 2 filters with the appropriate adapter fittings then
Old 01-31-2018, 12:45 PM
  #94
svslow's Avatar
I was planning to do the spin-on tractor filter as well until I came across this one.
Wix 24003
7 micron element
12 GPM
Ethanol friendly
Look it up
Old 01-31-2018, 01:00 PM
  #95
Lawhead's Avatar
Wix 24003
7 micron element
12 GPM
Ethanol friendly
Look it up
Nice find! Be awesome for post pumps, a lot sleeker and can just run it down the side of the car without having to find some sort of special spot for it !
XRP makes this but it's for the 044 and with the check valves already (If they ever become a restriction they will be removed) I see this as maybe being a restriction if they made them in the -10AN threads
Old 02-01-2018, 01:28 PM
  #96
drecpt83's Avatar
Where did you purchase that y fitting? I'm about to add a second aem 380 and that's exactly what I'm looking for
Old 02-01-2018, 01:53 PM
  #97
svslow's Avatar
They are all over eBay. Search "fuel pump y".
Old 02-01-2018, 03:58 PM
  #98
Lawhead's Avatar
Yeah they're all over ebay 25 bucks If i remember correctly
Old 02-16-2018, 08:12 PM
  #99
Lawhead's Avatar
Got the car tore down to swap heads and only got one head gasket lol
Also got the extension flange for the S400 frame
Here is what I’ll be using for wiring it’s 5 relayed circuits with harness to run to accessories then 5 to the switches as well has 5 constant 12V sources nice piece it’s all already put together and labeled.
2 steps forward 1 step back
Old 02-17-2018, 08:57 AM
  #100
Mastif's Avatar
Lawhead,
I have sent you a PM.
Thanks, Mark
Quick Reply: "How Original".......Billet S480 Fox Body
