LS6 vs Ebay Fab intake N/A and Boosted, dyno results.
Restricted User
Someone beat me to the punch, but I might take a shot at a TBSS vs old truck vs Ebay Fab intake on the dyno with the quad turbo 4.8.
Interesting results. Everyone says that the ebay fab intake doesn't perform so well out of boost, but once you add boost it doesn't matter.
The results are very different.
It made more peak HP way way up top N/A, but once you add boost to them, the power different between the 2 was almost eliminated.
Sadly, the point where the ebay fab intake overtook the LS6, was higher in the rev range than most people rev out their 5.3 turbo builds, which would make it a complete loss across the entire rev range for the average person.
Restricted User
Restricted User
Seeing how much more capable a TBSS is than an LS6, he dropped his TBSS manifold in favor of one of these ebay intakes. His rev limiter is set at like 6300.
With the way the LS6 stays with the fab intake up top with boost, I imagine the TBSS would easily have stayed ahead of the fab intake up to 7000 or so.
You could always increase boost to compensate for the HP loss, which makes some of this irrelevant, but for those already stressing their pump gas combos or turbo efficiency with high boost, increasing it much isn't an option.
Restricted User
And someone I accidently highlighted and typed over my 2nd sentence.
"A buddy of mine recently swapped out his TBSS intake for an ebay fab thinking he would pick up some power with this small twin combination."
Restricted User
Doesn't the fastest SBE rev out to ~8300 with a hi-ram? Seems like its worth it assuming the combo is correct.
Hate how these LS magazine guys always put together a big money NA engine and run diddly for boost. 7lbs? What the hell is that… We need the comparison on a stockish build at big boy boost.
In general aren’t you looking for the highest average power over the entire run for the best ET? Since most of the ET is in the first half of the track, I’d think the TBSS or LS6 would be the obvious choice for the average street/strip setup. ESp in the power ranges they are testing in the article.
Most guys without OD or manuals are running a 3.2x-3.5x gear. I barely see 6400rpm at 160mph on what I consider street friendly gearing. My converter couldn’t handle the gearing load when I tried to rev it higher. I actually slowed way down when I dropped the tire size 2” and tried to rev it out more.
If you run a full out drag car and stall the thing to 6500 off the line with a short gear, that’s a different story all together. Street cars with street gearing/tires aren’t going to make the power to hit 7-7500+. I mean 7500 with a 3.27 and 28” tire would be 191! I get there’s slip to account for but most aren’t going to utilize that kind of rpm with a street gear IMO.
