Finally got the D1SC to the track...Like a walk in the park
Old 11-16-2017, 01:10 PM
  #81
UNDER PRESSURE MOD
The Alchemist's Avatar
Kudos. It's simple builds like this that made me chose Procharger a while ago.
Old 11-16-2017, 02:31 PM
  #82
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Thanks man. Took me a little bit to work some of the bugs out, but once it was pretty much set its been good. Now I just need that bracket from conan
Old 11-17-2017, 11:03 PM
  #83
RooRnZ28's Avatar
Nice run and build, wish I had more time to take mine to the track...
Old 11-18-2017, 06:23 AM
  #84
UNDER PRESSURE MOD
A couple comments now that I read the whole thread.
Belt slip. The problem with a static tensioner, is as the rpms go up, the belt WILL stretch, it's just simple physics. So now, the tension on the belt, and around the blower pulley, which is the load, is being reduced. The higher the rpms, the more slip, it's just physics. It's why almost every single higher hp car has a spring loaded tensioner, to keep the same amount of tension on the belt throughout the entire rpm window. If you can keep that same tension through out the rpm, belt slip should go away as long as you have the other stuff in line, ie a good belt, good pulleys, proper alignment, eliminate flex.
Exhaust. I run 1 7/8 headers, into 3" ypipe, into a 3.5" stainless works catback. It's ok, a little loud, but nothing that is too over the top. Sure, when you hit the happy peddle, it gets loud, but that's a good thing right? The other thing you can do, and I've considered it, is to put in a boost operated cutout. At like 4-6psi I think, it opens, and now you have all the free exhaust flow you could ever want. Lift, and the car is quiet. No manual buttons to hit, no forgetting to open it or close it. It's operated by your foot.
In the spring, I'm considering quieting down my exhaust a little more, and if I do, I'll put in the boost operated cutout just for the fun factor.
Old 11-18-2017, 07:20 AM
  #85
ddnspider's Avatar
I'm running 1 7/8 headers as well, but to a 3 inch y and then have an electric cutout before the muffler at the borla plate. Pretty sweet that for 50 bucks and no welding or anything I was able to drop the cutout in. Just cruising around with the cutout closed it's not too loud for me. Idle it sounds pretty angry between the cam lope and blower....but that's fine
I agree on all counts on the tensioner....just don't want to drop a grand on it as I don't plan on running much more boost. If Conan's bracket stiffens it up and I see 8 or 9 psi at peak I'm cool with that. Then make some tweaks to mainly the tune and see if it'll get a 10 in some better air. It's still be in the high 70s low 80s here.
Old 11-18-2017, 10:18 AM
  #86
UNDER PRESSURE MOD
I understand your situation, I was just trying to explain it better to others why a static tensioner just won't work effectively unless you can get a belt that doesn't stretch much.
Old 11-18-2017, 10:21 AM
  #87
ddnspider's Avatar
No worries, I gotcha.
Old 11-22-2017, 08:09 PM
  #88
11SECSS's Avatar
This thread is one going to stay tuned to
Old 11-22-2017, 08:28 PM
  #89
ddnspider's Avatar
Yeah going to head back after I sort out some belt slip and up the rpms a bit
Old 12-18-2017, 07:07 PM
  #90
conan's Avatar
Here's your brace on my car, I put 2 washers in between the tube and head unit. Add or remove if your spacing is a little different. The nut I sent on the bolt is just for shipping, bolt threads right in the head unit. Re use the corner oil pan bolt.
Old 12-18-2017, 07:17 PM
  #91
ddnspider's Avatar
Awesome. Looks good, can't wait to try it. Thanks for taking the time to make it.
Old 12-18-2017, 07:29 PM
  #92
conan's Avatar
No problem.
Old 12-18-2017, 07:45 PM
  #93
sbcgenII's Avatar
Conan your car looks amazing.
Old 12-22-2017, 06:11 PM
  #94
ddnspider's Avatar
Shout out to Conan! Shipped me a bracket and not only did it look great....the difference was holy crap!! It took literally 5 min to put the bracket on, I added about a half turn to the jbracket manual tensioner and took the car out. The car was stupid, a roll on in 2nd gear no downshift and it lit up the 295 50 16 MTs. I tried again at a lower rpm with some heat in the tires and it made at least another 2 maybe 3 psi and never felt like it leveled off. It pulled all the way to redline. It literally felt like another 100hp
I'll have to get the ls7 maf on the car now and retune it and get back to the track. Something to note is you can only use this bracket if you're running a 4 inch or smaller blower pulley as the spacer that has the bolt going through it to fasten into the blower barely clears the blower pulley with my 4 inch pulley. I can see light in between but that's about it lol. I'll have to check it to see after a pull if it clearances itself. Anyways, thanks Conan and here's a couple pics:
Old 12-22-2017, 06:14 PM
  #95
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
That's awesome!! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-23-2017, 08:42 PM
  #96
conan's Avatar
Good to see it helped and your happy
Old 12-24-2017, 07:21 AM
  #97
conan's Avatar
Thanks for the kind words
I also wonder if the mechanical tensioner is causing your J bracket to flex more than the spring tensioner systems from SDCE or the Aster ???
Old 12-24-2017, 09:13 AM
  #98
ddnspider's Avatar
I would imagine the mechanical tensioner does flex more since the spring tensioner should be what gives first. It's a noticeable difference even at idle. It doesn't sound like marbles in a coffee can now, you just hear more howl/air from the blower.
Old 12-24-2017, 11:26 AM
  #99
Midnight Blue GTO's Avatar
That looks awesome. How much for you to make me one too?
Thanks
Quick Reply: Finally got the D1SC to the track...Like a walk in the park
