Dyno day! 8/31/18 99 ws6 twin vs 3582 billet and 80e/8.8 swap - 11.4@126
#61
Well, didn’t make the progress I wanted too, wound up having to work today. But I got the rear end full of fluid and ready to go under, and the filter and seals changed in the 80e, I’m ready to get this stuff put in! When I changed the pinion seal I noticed someone had been thru the diff before, and it has solid shims instead of a crush sleeve. Winning. Need to look at some pictures and see where I’ll have to cut that support in the tunnel for the wiring plug.
#62
Got the rear in the car! Fits perfect! Absolutely in love with the wheel/lip combo on this car!
I have a big desire to slam it, but I don’t think that’s a good idea lol.
Did some playing around with my 07 hd, 80e all stock minus I tuned it. I could get 2400 rpm easy holding the brake and mashing it, gives me hope on this car. If I can hold the rears from spinning, I might be able to get some boost out of this turd before I launch.
#65
Might have too haha! Yea it’s been cold as hell here too, 3 days in a row we never got over 0, high of like -2 lol. With windchill it was like -30 or -40. I have a woodburner that I run and drip oil into, running full bore it will keep it around 55 degrees at 0 outside, so I’m not complaining. Also, thanks on the wheel figment! Very happy! I got lucky though, my lcab I made are maybe a 1/4 from the wheel/tire, I never even thought of that. So thank god for that lol.
#73
Repinned thd trans connector, added the second vss, and cut the ears off. Put her in! It’s al tight as heck but fits!! Time to build a crossmember and a tq arm.
The harness for the trans seems to be short, anyone else have this?? Pulled a little bit it wasn’t giving up lol.
#74
Made my catchcan haha. 2” sch40 pvc pipe and cap, 3/4x1/2npt Plex fittings, tecumsuh mower filter. I’ve got about $20 into it. Inside is stuffed full of stainless wire wool.
X member made, pretty proud of this receiver hitch bent masterpiece lol. It’s 1.25 .120 wall tube, just getting started on the tq arm and mount now. Getting closer!!
#76
It’s ghetto . I have a 5 gallon bucket I hung on the wall
And ran a ball valve out of the bottom, then ran a copper line over to the burner and drips in the top. It’s a deka forced air wood furnace I bought off FB for $300. I’ll grab some pictures tomorrow. It’s really nice, I change oil I just walk over and dump it in the bucket and burn it.
#77
Yeah the stock trans harness isnt gonna want to reach the 4l80e plug easily. When i bought my Nelson harness it was about 4 to 6 inches total which make it way more comfortable to plug in because while it switches the pins for you it serves as an extension as well.
#79
I e alr day repinned my stock plug, not a big deal to put it back. But looking at those prices, I think I’ll just cut off a plugfrom a donor vehehicle with a couple extra feet of wire and solder the connections. The wires are shitty on mynllug where they go into the plug, super soft coating from years of oil soaking.
