WS6 w/ Powerdyne supercharger (new updates, blower mounted)
#49
Took it for a spin tonight. Datalogs show 7 psi by redline which exceeded expectations for a 3.4 inch pulley. I was hoping for 6 so I am super pleased with the whole thing. She only has 13.5 degrees of spark in her with the IAT modifier. Intake temps were 169 by the end of the pull. Shes certainly a hair dryer but all in all, I am really really pleased with how it turned out. I have an idea in my head for the intake setup that should look pretty cool when I am done with. That will be for another day though. For now, I am just happy to wash this thing.
#51
i had tried to msg you, needing some info on your install if you dont mind sharing info, i have the same setup that im installing on a 02 ss, got the head unit for free so figured why not, just needing help on the spacers and bolts for it, i have a waterjet to cut what ever i need as far as the bracket goes so no issue there
#52
#53
After snapping the belt I had to pull the blower. Looks like the cog on the pulley side had some sharp edges on a tooth after something must have got in there and bounced around alittle. After a little filing it was good as new, threw a GT belt on it and put all back together. Here are some finished shots of the lower air intake and the whole setup after routinng my breather line and bypass. Shes on stock MAF + SD setup.
The following users liked this post:
Rickys2003svt.cobra (08-30-2020)
