Pin Crank? 416 LS3 w/ ATI Damper
Running a 416 LS3 using a Callies Compstar CPI-APO31N-CS58 crankshaft along with ATI TBSS Damper ATI-917286. Looking to add on LSA supercharger in near future but curious whether I need to pin the crank or not.
If so, any specific kit recommended or would this one even work?
https://www.ebay.com/itm/192427058295?ul_noapp=true
Thanks
Thanks
Absolutely pin the crank. It’s easy to do an peace of mind that your not going to destroy your new dampener or crank. That kit looks your basic install. A angle drill helps out if your doing this with the motor in. Also use a better grade drill bit than what is in the kit. Take your time, tape your drill bit for depth, use cutting fluid.
100% pin the crank on a supercharger.
As Steve said, do it anyway. Mine is turbo but for peace of mind i did it while fitting my ATI crank, took me about 20 minutes.
Are you sure there is no key on the crank/ati hub? My current Callies/ATI was already keyed and I did not have to pin it. I have the LSA kit from ADM (self installed in 2014). My current engine is stroked/416 with the LSA kit.
-Don
-Don
I pinned my stock crank/damper. When I went forged aftermarket, we used the key as the crank and ati hub were setup for it.
IF no key, I agree, pin it...
ATI has a kit for their damper...
http://www.atiracing.com/instruction...LS7-Damper.pdf
-Don
-Don
