What are some good Boost Controllers these days....2018 It's getting close for me to be installing my single Huron Speed Turbo kit in my car, gathering parts, tearing my car apart, etc. What Electronic Boost Controllers are people using these days? I like the Turbosmart E-Boost 2 but it won't fit into my current 2 gauge pillar pod since it's a 66mm unit. Can you even get a pillar pod that accepts 66mm gauges? My car is mainly a street car, might go to track once a year. I would like to have the ability of having 3 different boost levels. Say 7.5, 11, 15 PSI What are you guys using, pros, cons? Thx... |
I have the boost/pulse combo, I love it. |
This Is going in an f body right? If so, do it like this. https://cimg4.ibsrv.net/gimg/ls1tech...a9b08efd01.jpg |
Ecu with boost controll Hi Bill, MOST MODERN ECU's have the Boost Controller INCLUDED. ( internal ) SO I ASK why SPEND the EXTRA CASH ? Lance |
Boost/Pulse Combo? Yes, this will be for a 2001 Camaro SS M6 Game ova - I'd love to put it there but I already have my Fan switch, Bass control knob and cut out switch there. |
Originally Posted by Billiumss
(Post 19832219)
Boost/Pulse Combo? Yes, this will be for a 2001 Camaro SS M6 Game ova - I'd love to put it there but I already have my Fan switch, Bass control knob and cut out switch there. https://cimg0.ibsrv.net/gimg/ls1tech...5d38ff596c.jpg |
The eboost 2 fits in a regular A pillar gauge pod, you just have to dremel the opening bigger. It still looks and fits fine. |
Originally Posted by Pantera EFI
(Post 19831864)
(Post 19832277)
The eboost 2 fits in a regular A pillar gauge pod, you just have to dremel the opening bigger. It still looks and fits fine. Do the current gauge pillar pods for sale now days have bigger openings or just larger in general? |
(Post 19832328)
I did think of that but It's not even close. My current gauge pod is about 14 years old, not sure of brand. 66mm on the Turbosmart is bigger than the OD of my pod. Do the current gauge pillar pods for sale now days have bigger openings or just larger in general? |
Almost $600 for an Turbosmart E-Boost 2? Does it even do true progressive boost? Boost by speed? Boost by RPM? Seems ridiculous to me! You can buy an MS1,2,3 ECU for that. With better boost control features... and program it to do 20 other things. Just my take. |
(Post 19832463)
(Post 19831864)
(Post 19831864)
Hi Bill, MOST MODERN ECU's have the Boost Controller INCLUDED. ( internal ) SO I ASK why SPEND the EXTRA CASH ? Lance Whilst I havent used it, on paper this looks to be about the best value/versatile out there. https://sirhclabs.com/ |
(Post 19832499)
Lance, add automatic transmission control and I'll be your next order! There are ecu's already out there that can control auto trans and boost ( which as Lance says, boost control is one of many standard features ) |
(Post 19832532)
(Post 19832528)
Most guys here will still use the factory ecu though. Whilst I havent used it, on paper this looks to be about the best value/versatile out there. https://sirhclabs.com/ wow, that looks amazing. thats miles ahead of the eboost 2 as far as GUI and # of set points |
EBoost2 is very good....but certainly not the most user friendly in many ways. But I guess that's to be expected with no proper head unit or buttons etc to make it easy. I've used many controllers over the years...but nothing I've seen compares to the above one for features vs value for money Although it has been a long time since I've used a standalone, simply because any cars I work at always have aftermarket ecus. But there are loads of others, Plex, HKS, Blitz, Greddy, Gizmo etc etc and they do all make very good products. But often expensive, and still lacking in some respects. |
(Post 19832528)
Most guys here will still use the factory ecu though. Whilst I havent used it, on paper this looks to be about the best value/versatile out there. https://sirhclabs.com/ |
There are only complications if you make them, and the "bells and whistles" are basics IMO, especially when it's a boosted motor you're talking about. You dont need a racecar dash unless you want a racecar dash. But yes, the stock ecu can run the engine just fine in many cases. |
© 2024 MH Sub I, LLC dba Internet Brands
