4th Gen Camaro Street Car New PB 7.81@177
#61
$200 for a billet reluctor lol **** that.
#63
With the tfs 245's it makes peak power around 7,800 with the ljms stage 4 turbo cam. Power falls off around 8,200. I shift first at 8,150 everytime.
Im going to go with a little bit more camshaft on this combo and try to squeeze another 500 rpm out of it with a super similar size. Bewley has a new lobe design for me to try out. He says they are similar in size but a little less ramp aggressive, easier on the valve train, and they are carrying power slightly higher because of it.
#65
This car is a beast, well done.
I agree on the 24x wheel. If it aint broke, don't change it.
#66
I agree to the wheels having issues though. That is why evertime a crank comes out around me the reluctor gets aligned and tigged. I havent had any issues since my first learning curve. Turbo 5.3 and reluctor continued to move. Along the lines of being 10 degrees advance.
#68
Ive even seen resolution issues with 58x stuff when a weak batter or charging system is present. Due to the 24x sensors being a higher voltage they have a stronger charge. Usually not an issue until over 7,700-8,000 but Ive seen it more so on 58x then on 24x.
#69
My last two engines have been 8,000+ rpm setups. This one I revved the bottom end to 8,800-8,900 a few times when I had the rec port heads on it testing shift drops and such.
#72
I put 5-6,000 miles on the car a year. Most of the street miles are abused as well lol.
#73
Yes actually they do wear quicker. While I ran the dart pro 1 ls3 heads for 2-3,000 miles. They had a 2.165 intake valve. I encountered a "rev limiter" sooner and sooner. Eventually I ruined the heads and when I pulled them apart I realized why. All of the intake valve springs were within a half inch of height. Just trashed. So since I switched to the TFS heads with a slightly smaller valve. My plan is/was to change them maybe mid summer?
#74
Im actually having him make one for me right now. He talked me into it. Trying to get another 500 rpm out of the combo.
#79
After the second try I was tired of it. Third try it finally stopped leaking.
