Twin turbo yukon denali
Hey guys, need a little input. so i have a 2001 yukon denali original block and crank, 4th gen rods with flat tops from a gto. square port heads and truck intake. ls9 head gaskets. so its about 10.5 compression.
So i installed forward facing headers and precision t3 .82ar vband flange turbos. 3" pipes to the axle with straight through mufflers.
so with 7.5psi in the manifoldi am seein about 25psi backpressure at 5500rpm.
My question is i keep reading all over the interwebs of people with similar sized stuff but i know there is no way 25psi backpressure is correct. needs to be under 2:1 has anyone else had any experience with these things?
welded in an o2 bung before the turbo in the collector. drill/tapped a o2 plug 1/8npt. screwed in fitting with a nipple. run vac hose to a boost gauge. its a little bouncy but definitly makes it way over 25psi.
What turbine size on the turbos. T3 is just a flange size turbine size effect back pressure alot. What compressor size. In my opinion size ratio between compressor and turbine can effect backpressure also.
