LSA SC'er accessory drive pulley system......on an LQ9 engine.....anyone done it?
Does it allow you to keep ALL of your factory accessories? A/C compressor, alt, power steering pump......In their factory locations..?
Or do any of them have to be relocated?
Did you need to use a 2007+ Truck water pump?
Any issues you ran into?
------And I assume if it fits onto any LS style engine...it will also fit the same on my LQ9.......correct?
Thanks....
Thanks....
I used the Modified Fead that chevy sells, I'm pretty sure it used the corvette water pump and spacing https://www.texas-speed.com/p-3629-g...ve-system.aspx
Here is a picture on my S10
What about the power steering pump, stays put?
Can you use an 8 rib belt for the SC'er pulley?
Is that a 3 belt system?
The kit is made for putting the LSA engine or just supercharger into a swap vehicle. It uses all factory GM parts. So you would use nothing from your original truck setup. It uses 3 belts 1 for AC one for the accessories and one 8 rib for the supercharger.
There are aftermarket kits that will let you use the truck accessory setup.
It requires the use of the 2007+ water pump, or you can buy a spacer to use the LS water pump.
So that LSA drive system you have...I think is exactly what I need. Also, 8 rib is what I will need. 1,000+ RWHP for sure......
