1956 chevy 5.3 7875 turbo
so monday i dropped the block and heads off at the machine shop.....new cam bearings , lightly resurface heads and install the new btr springs.
last night i managed to get the hot side pipes all wrapped and coated....
also got my holley pan the other day and managed to drill and tap for turbo oil drain.
i was happy to be able to do this as i have a mast oil pan on my nova and it was much thinner and i had to weld it in. holley was significantly thicker...
well little update.... this week i got the block and heads back, i had .005 taken off the heads just to clean it up a bit, and new cam bearings installed. then i went scrubbed the crap out of this crusty old thing..... busted *** and got the short block together earlier this week.
i checked all the ring gaps and all the top rings were .019-.022 most being .019. I opened them up to .024-.025 ish... the bottom rings were all at .027-.028 i left those as is .
and tossed in the china head studs....
thursday i sand blasted all the covers and clear coated them , got the heads, water pump, oil pan and all accessories.
she's looking pretty good for a old junkyard motor....
#33
now too bad i gotta put this ugly old truck intake on it!
question.....i have this intake its a earlier drive by cable . what is every one doing to plug all the vaccum ports and purge valve stuff?
this thing has more holes in it than swiss chees.....
#35
Will usually end up using all the vacuum ports plus some. Brake booster, fpr, trans modulator, bov, map sensor etc
edit- the barb right below the purge valve hole is not vacuum. It is normally the fresh (clean) side of the pcv system. I just throw a vacuum cap on and a hose clamp.
