Melted a piston - unsure why.
http://www.msextra.com/doc/triggers/crankrelearn.htm
It sounds like the case procedure just calibeates the computer to the sensor and will not compensate if your reluctor is off or cam timing is off. I've never gotten the CASE relearn to hit the 4k rev limiter on setups I've tried with EFI live.
Based on this link
Put it all back together, and fire it up with an old school timing light on it. Go into the scanner and lock the timing on 20* and all should jive. This is how we found my friends' MS retarded 6*
I'd really only consider checking this on an aftermarket pcm or where an aftermarket crank or reluctor wheel is used. I check my own stock crank stock pcm stuff because, well I've blown up enough **** this last couple years. I'm jinxed.
My knowledge is based on my 1000+ turbo tunes, thirty years of tuning turbosupercharged engines, as the OEM engine supplier for Jerry Wiegert (Vector Cars), Indy Car racing (Menard V-6 & Cosworth), Rally Racing (RS-200 & Subaru EJ-20), Marine BBC Twin Turbo engines (PFM), Turbo LS engines in Sand Cars/Street Cars, etc.
MY INVENTION of the 60-2 (GM 58X) Crankshaft Target Wheel in 1986 has allowed the ECU I MANUFACTURE to operate an engine with a Spark Accuracy of 1/4 Degree.
THUS I know how to tune at a Spark Instant of 60 DEGREES ATDC at the Start Line WITHOUT engine damage.
GM also uses the SAME METHOD to protect Truck 4WD drive trains using a LOW Spark Advance to LIMIT Torque.
THE DIFFERENCE is the GM Truck AFR is close to 14.7 NOT 11.2.
Good Tech, Loud Mouse, as you are one of the few here who knows this fact !
Lance
NO AFTERCOOLER ???
This too ADDS EGT increases.
SURE detonation can be a result of a bad tune AND the added information provided by the OP points to that broken piston, NOT a MELTED piston. ( OP's Question)
BUT/INSTALL an EGT Gauge.
A HIGH EGT is a result of a too low Spark Instant.
WHAT is your EMAP at 11 .lbs ?
WHERE is your EGO/UEGO sensor located ?
MY tune target is from .866 -.902 Lambda AND finding the lowest EGT, found with CORRECT Spark Advance.
Lance
What is CORRECT timing and how are you finding it? EGT only??
I also question the definition of correct AFR. I'm a total turbo newb but have plenty of Nitrous experience. I see a crap ton of turbo tunes in the 11.5AFR range and they seem to survive and make good power. I do think it's pig rich from previous experience but wonder if turbos differ in AFR needs from nitrous and why?
Lance
In the absence of a dyno....it's kinda a guessing game and people take various routes to achieve their goals.
His posts kind of remind of that one dude who also took an arrogant tone fairly often (PrincessTalon), and also spoke in parables and other twisty riddle me this type stuff. Always worth a good laugh either way.
