Finally hit the dyno 1139hp / 919tq
Ran out of time but managed 1139hp @ 919tq.. Had to let off at 6500 due to seeing some fuel pressure drop, pretty stoked after working on the car for the last 12 months.
on the street can only run like 15lbs... had it up to ~20 and she broke loose at ~65mpg. I have some 275/60/15's with some skinnies up front i need to mount and put on, but thats mostly for the track.
at 15lbs of boost she made like ~950 hp tho, just put a new set of 315/35/17's MT ET streets with that R2 compound, and they hook pretty good.
https://www.summitracing.com/parts/mtt-3571
Thanks... this was the thread from a year ago with nothing in the car, finally glad I can drive it.
https://ls1tech.com/forums/forced-in...rogress-2.html
Well, made some test hits... Car was a handful for me, still getting use to the power. Just leaving on the foot brake, no boost controller so it rolls out then bam, hold on. Maybe blowing thru the converter, when i shift (i have it flashing yellow on the dash at 7K rpm) it immediately goes right back to yellow telling me to shift again. With that and other small issues i had a good time. Best was a 9.8 @ 144 on like 15lbs of boost.
