Dirtybird
Old Sep 16, 2018 | 05:45 PM
Transamthunder's Avatar
Default Dirtybird
So far I am working on a 1998 Trans Am. Mostly collecting parts as overtime from work allows. Last year I picked up a 5.7 for 400 bucks with a broken intake and exhaust springs. Swapping in a t56 that I am converting from a corvette since it has the triple syncroes. It is getting a Ssr mainshaft since it has a 32 spline count and works with a Turbo 400 shaft as well.
Old Sep 16, 2018 | 05:50 PM
rwb's Avatar
rwb
You do realize that the 5.7 ls1 won't hold that much boost. That's why everybody started going 5.3 or 6.0. The 5.7 will be good for around 750 hp with good tuning. Some will say more hp with tuning others will say less hp.
Old Sep 16, 2018 | 05:57 PM
Its all in the prep. Its gonna hold the same power as a 5.3 or 6.0 on the internals. The blocks themselves are fine up to 900 before you need to start gusseting things. Gapping your rings out for boost off the bat goes a long way to help Is this the best engine to use, nope. I agree, but I couldnt find an L33 at the time, so this was the good deal i found at the time.
Old Sep 16, 2018 | 07:53 PM
Old Sep 16, 2018 | 07:58 PM
Act twin disc
China 76 64mm turbos
Old Sep 16, 2018 | 08:11 PM
Unlucky subject for boost
Engine tore down with parts bagged up.
Hole for intercooler cut in front bumper
Btr .660 dual springs
Elgin 238/242 .595 lift lsa112
Old Sep 16, 2018 | 08:24 PM
Corvette trans modding for fbody engine mount with ssr mainshaft, and z06 1 piece counter shaft
Mistakenly bought wrong input shaft. You can see the difference on the end of the shaft between double and triple syncros. Trying to keep my research up along with buying parts
Old Sep 17, 2018 | 01:32 PM
transam69230's Avatar
What did you put on the camshaft when you installed it?
Old Sep 17, 2018 | 06:12 PM
moly lube
Old Sep 20, 2018 | 11:41 AM
Like the stuff you use on ARP headstuds?
Old Sep 21, 2018 | 04:24 PM
Photochop's Avatar
Thats a big cam, too big.
Old Sep 30, 2018 | 04:47 PM
JosephIV's Avatar
That is a big cam. It's like a "Stage IV, Non-turbo Cam" lol. I'm interested in the results. I say send it and see what she does!
Old Sep 30, 2018 | 05:24 PM
qweedqwag's Avatar
Damn thats a lot of moly but everything is better with a lil bit of lube.
Old Nov 24, 2018 | 11:00 PM
Finally getting around to setting in the engine
Old Nov 24, 2018 | 11:03 PM
Still tearing into the trans to swap a bunch of parts, bit the engine can sit like this for a minute.
Old Dec 23, 2018 | 05:41 PM
just what came in the ARP package.
Old Dec 23, 2018 | 05:43 PM
why I decided on this one. Wanted to see what a magic stick 3 spec might do with boost. This one is from Elgine, and has inder .600 in lift, bit it should be faurly similar. There has been a few guys try the magic stic with boost and weirdly enough liked it.
Old Jun 22, 2019 | 03:01 PM
Gonna try and just drop in the whole album
Old Jun 23, 2019 | 03:00 PM
Dynomax makes'em in 3 flavors. Loud, louder, and f@#k you. This is the 3rd one.
Old Jun 23, 2019 | 03:03 PM
Bosch 210 injectors with some Ebay fuel rails on what I believe is a Professional products Typhoon intake
