Track guys, how do you keep the iats down in the staging lanes?
So so I open my hood. Cut the engine off. Put an electric water pump. I still don’t see that cooling my iats off. The compressor housing and intercooler and pipes get heat soaked because no air is flowing through them. Cooling the block off isn’t going to help lower my air temps. When I kill the car, the exhaust heat travels over to the compressor side and heats the **** out of it. Then I’ve got to fight to cool that down. I see that being a huge issue at the track. Especially in this weather. And like I said it gets heated in traffic. Thanks for your input tho. O and thanks for the temper tantrum. I had a good laugh. Lol
Agree. Methanol or water injection is the best because it acts on the air charge itself rather than the objects the air charge flows thru. Yes - over a sustained period of time the length of pipe from the injection point to the throttle body might cool down, but at most your run is not going to last more than 15 seconds so the temp of the charge pipe at that location is moot.
Any other method to cool probably won't be nearly as effective (fans for example) because of the inflated ambient air temps at bumper level parked on asphalt or cement. Don't believe - then next time parked in the staging lane, shoot your infared temp gun at the ground surface next to your car. If the local area weather channel says it 95 degrees, then the asphalt surface could be as high as 120 or higher. As a result the air above the surface will be much higher than ambient.
So fans pulling that heated air thru your heat soaked FMIC won't cool much from the air in front of or under your front bumper because it might be as high as 110 degrees. WHY? Because there is only about a 20 degree differential between the air above the surface and the heat soaked fmic and charge pipes.
The greater the differential in temp between two objects the quicker the transfer of heat from the warmest object to to the coolest object.
Example: stick a red hot piece of steel into a bucket of cold water and it cools almost instantly. Stick the same piece of red hot steel into a bucket of boiling water and it won't cool nearly as fast. The reason for the time difference is the temp differential between the two.
Cost wise, two good Spal puller fans behind your fmic will cost about $300. IMO a good methanol injection system will cost more but will be much more effective.
hey thanks! I’m not struggling tho. I’m just asking questions and getting feedback. If you want to be in the douche crew too then be my guest. I didn’t **** in anyone Cheerios nor did I disagree with anyone. I haven’t been aggressive to anyone either. I’m just trying to learn as I go. I like to hear people’s opinions (when they aren’t being negative) and ideas. That’s how you can learn. I’m having no issues with my car. If I leave it as is it will be fine but I’m that kind of guy that likes things better than the average person. That’s what separates faster from fast. This is my first turbo build and I’d rather not break the engine so I’m trying to be cautious. Not sure what your deal is but whatever.
Restricted User
Don't pull timing until ~160 IATs. IATs below coolant temps are just going to get heated when they enter the cylinder heads and hit those nice big aluminum heat exchangers, valves, and cylinders.
Once you're over 10-12 PSI, then you can start considering IATs a little more. You're not quite there yet.
Water/Meth is the most reasonable answer here. $200 or so for a basic kit and the only time you'll ever think about IATs is as a failsafe for the meth pump.
I run an aux inline electric water pump (toggle switch activated):
Dual intercooler pumps run while key is on, 3 heat exchangers, large intercooler tank, E85, meth.
Also have the fans come on...
-Don
-Don
Running meth/water, my AITs were 110* in the staging lanes. They were 70* at the end of a run . This is with a whipple 2.9 @11-12 lbs boost. Single .625ml nozzle. Im Sure they would be a lot cooler running straight meth with dual nozzles. My sensor is in the bottom of the intake
