Notices
Wastegate size?ís
Old 11-23-2018, 01:09 PM
Drj8787's Avatar
Default Wastegate size?ís
Is it better to use two smaller wastegates one each bank or just one larger one on one bank?
Drj8787 is offline
Old 11-23-2018, 05:17 PM
If you use one large on you will need it to feed from both banks. Some have done it with it on only one bank but it isnt the right way to do it.
jordoza is offline
Old 11-23-2018, 09:06 PM
truckdoug's Avatar
unless you are keeping the banks divided right to the turbine inlet, a single with priority flow best for simplicity sake
personally i prefer to put my gates right on the turbine housing
truckdoug is offline
Old 11-24-2018, 08:58 AM
01ssreda4's Avatar
I just tuned one, with a single 44, that made 12 psi on as 7 pound spring. Gate is not directly in the exhaust flow path due to the design of the hotside. Since mine is divided, and I had a 44mm already, I just added a second one, one to each side, and tried to get them more in line with the exhaust flow. I think it's gonna work well.
01ssreda4 is offline
Old 11-24-2018, 09:10 AM
Drj8787's Avatar
well the reason I ask is I feel it will be difficult to give a single one priority and have it vent both banks.
Drj8787 is offline
Old 11-24-2018, 10:30 AM
Two wastegates, one on each bank, is the easiest and safest way to go. If the merge and location is not right on the big single it will creep up top (depending on turbo size)
fif_gen_powa is offline
Old 11-24-2018, 11:48 AM
Drj8787's Avatar
on3 7875. I'm going to put it where the battery is/was haven't got started yet just ordering all my parts as of now.
Drj8787 is offline
Old 11-25-2018, 10:04 AM
I had a comp 78/75 with a single 45mm Wastegate (with a not so great merge design) and it worked fine. Switched to a pt88 and it had bad boost creep on a 10psi spring would hit 18-9psi up top. This was on a ls3 motor huronspeed gen5 Camaro single turbo kit, had to add a second Wastegate to get it under control.
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
