Funkster's 2009 G8 GT
Because this car is eventually going to have an LSA setup on it, as stated in the first post. The cam going in is also a supercharger cam.
Do I have this kind of thing to look forward to from you each time I post? You could save us both some trouble and stop looking at the thread if you don't like my approach.
Have been on hiatus a few days and the plan is (rather, was) to get some work done and hopefully get the cam swap buttoned up this weekend. However, this hobby is not forgiving to our plans.
I went ahead and finished stripping down the front of the engine.
I pulled the cam and all looked well with the removed components.
Unfortunately...I forgot to turn the lights off so I was able to see the cam bearings, haha. The wear on the first bearing didn't bother me much, it was the second bearing that was cause for concern.
So...these are going to need to be replaced. This means my plan for the weekend has changed. I will now be pulling the shortblock out and tearing it down for the machine shop. We will see how everything looks on tear down. This may end up being a complete refresh, if anything looks crazy I will weigh my options. There is already temptation to forge the bottom end, but at my goals it really isn't needed.
In the mean time, I did get my rocker arms disassembled. This press made the process pretty easy.
All the internals from the arms.
Empty rocker arms.
Will get started on removing the rest of the engine today. On the upside it will make reassembly on the stand a lot easier than in the car. Also will give me a chance to wipe down the engine bay.
Empty rocker arms.
Cam bearings in one of my 5.3s looked like those. So I took it to the machine shop and had them replaced, took my cam with me when I picked it up. Needless to say it wouldn't fit anymore and by the time he dingle honed the new bearings for clearance they looked just like my old ones.
Well today I got everything torn out. Short block is currently loaded up and will be going to the machine shop tomorrow to weigh some options and make a decision on what to do.
Engine all hooked up and ready to pull.
Engine on the stand.
Stripped down to the block and rotating assembly.
Loaded into the trusty Honda, haha.
FWIW, my bearings looked the same in my G8 when my DOD cam took a crap, its the DOD cam does that and is pretty notorious for causing issues down the line. I put in a BTR PD 2 cam last year and bearing look unchanged when I put the new cam in. Coming up on 40k miles with the cam being swapped and a LSA added on top making just under 650whp with no danger in sight so far.
Friend did have an Escalade with some of the mixed in DOD hardware and supposedly was the reason for his drop in oil pressure and eventually destroyed bottom end.
After talking to the machine shop today I will be doing a full refresh. The list includes:
Block cleaned, honed, surfaced, clean up hone and finish clean.
Crank will be refinished as needed.
Durabond Teflon Coated Cam Bearings
King Main and Rod Bearings
Hastings rings which will be gapped for boost.
It will probably be 2-3 weeks before I get it back. In the mean time I am going to go ahead and install a few front end related components (Rack bushings, sway bar) and if my trans cooler parts ever show up I will get that hooked up.
#32
#37
They have milled and cleaned a few sets of heads for me. This will be the first time I have had them do any rotating assembly work for me. Their reputation is pretty stellar. I do know of a local guy who had them rebuild his L76 and I believe he’s put about 30k on it since then without issue.
#38
A few things over the past days. Nothing major as I am waiting for parts and the engine to come back from the machine shop.
I received the following:
ATI Balancer
Crank Pinning Kit
Oil Pan Gasket
Rear Cover Gasket
Rear Main Seal
BMR Steering Rack Bushings
LS3 Waterpump
Got a couple odds and ends completed as well.
I sat down with my heads back from the machine shop to get them assembled. They ended up cleaning up really well and I had the outside surfaces glass beaded as well as had the heads surfaced.
Got them all put back together with BTR Dual Springs, lapped in valves, new seals, etc.
I mentioned the other day that the trim and pieces for the HSV gauge pod and cubby came in. I finally got them all cleaned up and am vinyl wrapping them black as the silver does not match the 2009 interior. I ordered the Black 2008 Seat/Traction Controls and Radio/HVAC faceplate. I got a few pieces done, but I am not sure how well it will match with the 2008 pieces until I get them on Tuesday. If they don't match up well I am planning to paint them.
Trim pieces:
Cubby wrapped. I like the look of the silver button, but I may end up doing it in black too.
Next I wrapped up the shifter trim. A word of warning...if you are a perfectionist, this job is a bitch.
ATI Balancer
Crank Pinning Kit
Oil Pan Gasket
Rear Cover Gasket
Rear Main Seal
LS3 Waterpump
Trim pieces:
