Originally Posted by badass68
(Post 20026057)
And again. Why is this build in the forced induction section? Do I have this kind of thing to look forward to from you each time I post? You could save us both some trouble and stop looking at the thread if you don't like my approach. |
Sorry. Missed the future blower. |
6 Attachment(s) Have been on hiatus a few days and the plan is (rather, was) to get some work done and hopefully get the cam swap buttoned up this weekend. However, this hobby is not forgiving to our plans. I went ahead and finished stripping down the front of the engine. Attachment 715669 I pulled the cam and all looked well with the removed components. Attachment 715670 Unfortunately...I forgot to turn the lights off so I was able to see the cam bearings, haha. The wear on the first bearing didn't bother me much, it was the second bearing that was cause for concern. Attachment 715671 So...these are going to need to be replaced. This means my plan for the weekend has changed. I will now be pulling the shortblock out and tearing it down for the machine shop. We will see how everything looks on tear down. This may end up being a complete refresh, if anything looks crazy I will weigh my options. There is already temptation to forge the bottom end, but at my goals it really isn't needed. In the mean time, I did get my rocker arms disassembled. This press made the process pretty easy. Attachment 715672 All the internals from the arms. Attachment 715673 Empty rocker arms. Attachment 715674 Will get started on removing the rest of the engine today. On the upside it will make reassembly on the stand a lot easier than in the car. Also will give me a chance to wipe down the engine bay. |
Cam bearings in one of my 5.3s looked like those. So I took it to the machine shop and had them replaced, took my cam with me when I picked it up. Needless to say it wouldn't fit anymore and by the time he dingle honed the new bearings for clearance they looked just like my old ones. |
4 Attachment(s) Well today I got everything torn out. Short block is currently loaded up and will be going to the machine shop tomorrow to weigh some options and make a decision on what to do. Engine all hooked up and ready to pull. Attachment 715664 Engine on the stand. Attachment 715665 Stripped down to the block and rotating assembly. Attachment 715666 Loaded into the trusty Honda, haha. Attachment 715667 |
FWIW, my bearings looked the same in my G8 when my DOD cam took a crap, its the DOD cam does that and is pretty notorious for causing issues down the line. I put in a BTR PD 2 cam last year and bearing look unchanged when I put the new cam in. Coming up on 40k miles with the cam being swapped and a LSA added on top making just under 650whp with no danger in sight so far. :) Friend did have an Escalade with some of the mixed in DOD hardware and supposedly was the reason for his drop in oil pressure and eventually destroyed bottom end. |
After talking to the machine shop today I will be doing a full refresh. The list includes: Block cleaned, honed, surfaced, clean up hone and finish clean. Crank will be refinished as needed. Durabond Teflon Coated Cam Bearings King Main and Rod Bearings Hastings rings which will be gapped for boost. It will probably be 2-3 weeks before I get it back. In the mean time I am going to go ahead and install a few front end related components (Rack bushings, sway bar) and if my trans cooler parts ever show up I will get that hooked up. |
If I was that far deep into the motor and had it pulled and at the machine shop I'd have thrown some forged rods/pistons in it at least lol. |
Originally Posted by ascastil
(Post 20031098)
(Post 20031098)
Originally Posted by Busted67
(Post 20031109)
spend your own money not his. |
What machine shop do you use here in Iowa? I don't have a relationship with or trust anyone local to me. |
Originally Posted by 1969x11
(Post 20030047)
Originally Posted by BCNUL8R
(Post 20031216)
(Post 20031109)
(Post 20031634)
Eat a d |
Originally Posted by Funkster
(Post 20031630)
Working with Mid-State Machine in Ankeny. |
(Post 20031731)
I've heard good things about them when I asked around recently. Have you used them prior to this? |
6 Attachment(s) A few things over the past days. Nothing major as I am waiting for parts and the engine to come back from the machine shop. I received the following: ATI Balancer Crank Pinning Kit Oil Pan Gasket Rear Cover Gasket Rear Main Seal BMR Steering Rack Bushings LS3 Waterpump Got a couple odds and ends completed as well. I sat down with my heads back from the machine shop to get them assembled. They ended up cleaning up really well and I had the outside surfaces glass beaded as well as had the heads surfaced. Attachment 715636 Got them all put back together with BTR Dual Springs, lapped in valves, new seals, etc. Attachment 715637 I mentioned the other day that the trim and pieces for the HSV gauge pod and cubby came in. I finally got them all cleaned up and am vinyl wrapping them black as the silver does not match the 2009 interior. I ordered the Black 2008 Seat/Traction Controls and Radio/HVAC faceplate. I got a few pieces done, but I am not sure how well it will match with the 2008 pieces until I get them on Tuesday. If they don't match up well I am planning to paint them. Trim pieces: Attachment 715638 Cubby wrapped. I like the look of the silver button, but I may end up doing it in black too. Attachment 715639 Next I wrapped up the shifter trim. A word of warning...if you are a perfectionist, this job is a bitch. Attachment 715640 Attachment 715641 |
This is posted in the Forced Induction section, wheres the BOOST at ??? |
Lol how many times is that going to be asked here. He is planning on boosting it it's just not boosted yet. |
© 2024 MH Sub I, LLC dba Internet Brands
