83 mm t4 to 96 mm t6 change.
got a 55 degree day today and took the nova for a spin. with the new 80/96 devided t6 setup. the big turbine spools very nice. I really can not tell the difference. but on the 2step the 96 spools faster. to drive the car it feels about the same any rpm in the 3000 range with a light acceleration in high gear it starts spooling. I did a quick driveway 2step and with about 1 full second on the 2 step it is at 5-6 psi and climbing. =left
=left
=left
not sure if the dual 2 1/4 hotside is the big improvement or the old single 2 1/2 hotside feeding a devided turbine housing was hurting it but from a 83 mm t4 1.25 to a 96 mm t6 1.32 the spool is just about the same if anything it is better. if my little cam likes less backpressure it should be faster. thanks
=left
=left
