408 TT sizing Ran a pt88 on my old 370 and it worked great! Sold the motor kept the kit and turbo. Put together this 408 with that same old turbo and it's done making power around 5800rpm. Picked up a huron twin kit but now debating on turbo size. I'd like the car to pull to around 6300-6500. Anyone have any recommendations? How big on the turbine side do I need to achieve these kind of rpm? |
I currently run 6266’s .81 A/r on my 416 LS3. Peak power is around 6k rpm and boost comes on hard. For more rpm you could go bigger turbos or .96 A/r. Graph attached (10psi and 13psi). what are your power goals? https://cimg3.ibsrv.net/gimg/ls1tech...fa9ce6373.jpeg |
Dont necessarily have a power goal in mind. Looking for low 9s maybe clip an 8.9. I just dont know how to gauge sizing twins. The car has been 9.6s with the pt88 but my mph was like 137..the car falls flat after 5800rpm. Would like to carry the power out a little further and trap 145+ |
Originally Posted by turboed370
(Post 20026185)
Stock 317s stock ls6 intake. Cam is a custom grind very similar valve events to the ljms stg3 |
That cam probably peaks around 6200-6300rpm with those heads. A lot of guys running twins... surprised nobodies chiming in. |
(Post 20026185)
Originally Posted by Game ova
(Post 20026409)
I don't think your turbo choice was the problem with the 370. Should have been truckin up top imo, there are guys running 145 with the on3 stuff (7875)..... been 140 in a full weight f body leaving in vacuum at the track. Id say the problem was elsewhere. |
Cam and intake will determine rpms more than turbos. |
turbos will determine rpm more than cam and intake. |
(Post 20027966)
Originally Posted by subeone
(Post 20028000)
he needs a 88/100 or 85/100 for that 408 |
(Post 20028470)
No track times but I'm running T-Netics 66/65's with a .68 turbine. The turbine housings too small but puts out a Massive amount of torque. Only pulled it to 6400 and laid down something like 770/880. On the gate, don't remember how much boost pressure. 408 ci BTW. I think if I get larger housings I'll see the HP go up and the torque still be very high. I'd go with billet turbo's in the mid 60's compressor range with a Med-High A/R T housing. |
69/73s in twin config s400 frame |
(Post 20028000)
turbos will determine rpm more than cam and intake. load of bollox. |
(Post 20029240)
load of bollox. |
(Post 20029242)
Settle down stevie, for us here in the U.S, what is bollox? |
(Post 20029240)
load of bollox. |
(Post 20029429)
its true :cool: |
© 2024 MH Sub I, LLC dba Internet Brands
