Oops! Was out just playing just now. Well was headed to the gym in the goat. Nailed it about 50mph and the rpms shot up instantly and obliterated the tires. Checked my ebc and for some reason it spiked to 15.6psi. I have it set to 10psi max. And I supposedly had it set to dump the shit out of fuel past the 12psi map pressure. Ummm. None of that worked. Scared the sheet out of me. My cheap wastegate must have stuck? Now im wanting some 14-15psi in my life. Cuz OMG! I need to get to work now making way for that to happen! Holy crap it was ridiculous. Just thought you guys should know. Lmao. |
Cool isn’t it! |
Sounds fun! What kind of gate is on it? Our setups are actually pretty close! How much power did you make? (sorry to hijack) |
Originally Posted by 3 window
(Post 20027062)
Cool isn’t it! |
Originally Posted by CasperCasper
(Post 20027100)
Sounds fun! What kind of gate is on it? Our setups are actually pretty close! How much power did you make? (sorry to hijack) Its a speed daddy gate. It’s actually built pretty well but I think the clearances are too tight. I have a spare that I took out the box tonight and it’s pretty tight, so that’s what I’m guessing. I can hone the guide and polish the valve stem. And how much power? Well I haven’t dynoed it or ran it at the track yet. I plan on going to the track this weekend. It should be around 550-600rear wheel on 10lbs if I had to guess. It made around 400 wheel before the turbo. Maths say it should be about 672 on 10# but I don’t think it’s that much. Maybe if everything was perfectly optimized but it’s not. I figure I’m probably leaving 100hp on the table from optimum fuel, timing and exhaust flow. My down pipe is pretty restricted at the moment. Which will change soon. Very soon. |
May wanna invest in an EBC that has overboost protection. Kinda anxious to see how car gets down at the track. |
Still taking it to the track this weekend? |
Originally Posted by Game ova
(Post 20027115)
Originally Posted by BCNUL8R
(Post 20027127)
When you say dump the fuel, you mean cut the fuel right? You're safer pulling all timing and cutting fuel above a certain boost then you are dumping a bunch of additional fuel. No fuel, no spark, no boom, no BOOM. |
(Post 20027156)
When you say dump the fuel, you mean cut the fuel right? You're safer pulling all timing and cutting fuel above a certain boost then you are dumping a bunch of additional fuel. No fuel, no spark, no boom, no BOOM. I added a bunch more fuel figuring it would be safer to be richer than lean and in hopes that it would kill some of the power. I’m not sure how I could do a fuel cut but in my mind wouldn’t that be more dangerous? Seems like a lean condition for a split second? |
No fuel means no combustion so you can't hurt anything. Dumping a bunch of fuel when overboosting is a good way to pop a ringland. |
(Post 20027115)
May wanna invest in an EBC that has overboost protection. Kinda anxious to see how car gets down at the track. Unless it offers some way to cut fuel/spark safely and totally. All EBC's that offer an overboost protection....are simply saying they will try and reduce w/g duty if the device sees too much boost. But if a hose is leaking, or the gate seized etc etc....it wont be able to do anything because it is outside of its control. |
(Post 20027959)
An EBC cannot offer overboost protection if there is a physical problem with the boost control system itself. Unless it offers some way to cut fuel/spark safely and totally. All EBC's that offer an overboost protection....are simply saying they will try and reduce w/g duty if the device sees too much boost. But if a hose is leaking, or the gate seized etc etc....it wont be able to do anything because it is outside of its control. exactly. I thought that would be self explanatory by saying the wastegate got stuck. Took it about last night. Valve was seized in the guide. |
Kfxguy does your ECU have no overboost protection? |
(Post 20028003)
Ahh! I always thought hp tuners would let you do something nifty with it |
© 2024 MH Sub I, LLC dba Internet Brands
