LS3 with twin 67mm turbos... Which injectors/valve springs? Not gonna push it too hard with boost. Gonna keep it stock as its a crate motor. What size injectors would be good its staying on 93 gas? Probably 12lbs tops. Which valve springs as well? |
I would think 80# injectors. Are you going to swap the cam? If not I may consider, just leaving the stock springs, otherwise, what cam? I generally run BTR springs. Best bang for the buck. |
No we are gonna keep the original cam. But I do feel like a spring swap may help it at least a little bit in case we do decide to start turning it up. |
80lb injectors would work nicely for that setup. Pac 1218 springs are cheap and work well. BTR springs would be better. |
Can anyone link me to the right kind of injectors? |
Just do a set of ID1000s. Great injectors and will give you a little extra room if you decide to add a little power. |
Unfortunately those are out of budget. Anyone have a link to the correct set for a LS3 80s? |
You want Siemens 80 lb short with ev6 connector for ls3. Plenty of injector data online for those. I would get real ones, not knock offs. |
Perfect thank you! |
What are u using for ecm/harness? |
Stock |
Why such big turbos? |
© 2024 MH Sub I, LLC dba Internet Brands
