Truckdoug's turbo g-body malibu, now with more money lit on fire!
#82
This is way too fancy! Looking forward to the rest of the build up. I always enjoy your relaxed style of building and think you do a nice job on your videos. Keep putting up pics of your progress, I'm ***** deep into putting an 8.8 into the rear of my '02 Silverado RCSB right now. Way easier since it's leaf sprung, but has challenges of its own
#93
Not at this time. I use a 275/60 on the street and a 28x9.5 slick at the track. Might have to roll the lip a tiny bit but hopefully leave the chassis mostly stock (except for fixing the terrible factory fit and finish)
I am curious about how you guys are caging these cars. I'd love for my back bars to land on top of the rear axle upper spring perch to beef that area up, but it looks like I'd lose my rear seat that way
Also i'm pretty sure the rear springs have been replaced with some lift springs since it sits so high. I'm having trouble finding lowering springs with less than 150lbs rate I want....what are you guys doing for springs?
#95
every GM A/G body I've owned over the years has atrocious welds on the frame. I've been on forums with GM execs who were like yeah, fisher just had crap QC thats why they were never allowed to build truck frames and bodies. one even told me my '86 cutlass front end would be off square by 7/8 to an inch...I measured and sure as **** he was right.
#96
[QUOTE what are you guys doing for springs? ][/QUOTE]
I went to the local circle track supply and got some weight jack bolts to weld in over the top spring bucket. Then you would have to use a straight non pig tail spring and a different perch on the axle. You can get almost any weight spring and even run different weights on each side since the ride height is totally adjustable.
#98
#99
well it's all fixed up now. had to grind all the boogies out and zap it with my neighbors millermatic 211...my lil miller 135xlt just doesn't put out the juice to do a lap weld without serious preheat.
8.8 is in and functions as promised. I'm in house move limbo packing all my **** for the move.
here's some random *** yappin on my YT channel
