Where to locate oxygen(o2) sensors for turbo using Trick Performance manifold?
Short: title states it.
Manifold here:
https://www.shop.trickperformancepro...o-Manfiold.htm
Longer with engine details:
Stock cranked 5.3L from 2004 Silverado
Forged rods and pistons
Stock heads
cam: https://www.liljohnsmotorsports.com/...ge-ii-cam.html
Holley mid-rise intake
4l80e transmission
Current plan is to use the stock 2004 PCM.
It is installed in an offroad vehicle with some focus on looks(thus the intake).
Since the turbo is mounted on the passenger exhaust manifold and the driver crosses over to the passenger side, where should I be mounting the o2 sensors?
Manifold here:
Stock heads
4l80e transmission
wont the pressure and heat kill any 02 if installed pre turbo? I run mine after the turbo in the DP and my WB and no issues with a single pass side turbo setup.
Do you have to make any adjustments to the tune especially for the passenger side?
When running a merged turbo system bank to bank fueling is lost and your fuel is controlled globally over the whole engine. You can run dual turbos and get back bank to bank tuning.
Mine is exactly like kbracing. works fine. see this thread https://ls1tech.com/forums/forced-in...l#post19942630 and scroll to post 14. then on the other bank, its in the stock location on my crossover.
I guess the issue is you guys run a stock PCM in which case the 02s are not WB02s and thus can be installed pre turbo. I wasn't aware of that but I also don't run the stock PCM. I was putting the info out to the OP that his "plan to use the stock 2004 PCM" if he decides to change the EFI that he needs to be prepared to move 02 sensor placement. That can be rather annoying to preweld bungs and then have to uninstall to put new bungs in afterwards (not to mention ruin any expensive coatings applied). ALOT of the self tuning EFI's use WB02s and thus should not be installed pre turbo. Some that come to mind are Fitech, Holley (dominator, terminator, HP etc), FAST I can assume that the MS3 and micro squirt etc... basically anything that uses a WB02 to self tune should not be used pre turbo. If you guys say he can run a stock 02 pre turbo and hes sure hes sticking that route then hes good... if not well this is just FYI.
So are you saying that no special considerations to the tune need to be taken into account because of the passenger side o2 bank getting 'doubled' up?
I just have 1 in my downpipe and both banks are wired to the 1. I figure that's how I tuned the ve table with the wideband so minor adjustments with the nb from there should be fine. I did change my fuel General injector bank select to all 0s, but not sure if it makes a difference on my calibration. The pcm keeps the fueling between 14.5- 15.2. Stft only, I feel like the ltft remembers too much
