This would only happen to me.....
Old 01-30-2019, 11:57 PM
Game ova's Avatar
Default This would only happen to me.....
Here last week it was a fairly cool night, about 10-12 degrees. Hopped in the Camaro to go get some food, had no intentions on hotfooting the car..... was just driving the car to keep everything in good shape. As I was driving, I noticed that it was loud... hit the cutout button to make sure it was closed....no difference. Come to find out, the passenger side manifold was the culprit, pulled it off tonight...in two pieces, only two things holding it in place was the v band and wrap, it was broke off clean all the way around. As I was working I thought, sure is a lot of string hanging around the motor mount. Well, that's because the exhaust was being aimed at the mount when the weld on the manifold broke....frying it. With all that said, I'm going to shout out master torpedo heater, i've got the 135k BTU unit, and it took my uninsulated 24x30 garage from 5 degrees, to tee shirt and shorts temperature in 1 hour.
Old 01-31-2019, 12:08 AM
383z's Avatar
Wow!
That's a clean break!
Old 01-31-2019, 08:34 AM
Tramminc's Avatar
Careful with those heaters, they do need to be vented.
Old 01-31-2019, 10:24 AM
truckdoug's Avatar
judging by the sugar on the inside of the weld, I don't think it was purged properly
Old 01-31-2019, 10:25 AM
TastyBacon's Avatar
Wow! How was it welded, and how long ago?
Old 01-31-2019, 10:48 AM
Game ova's Avatar
Agreed, I keep two windows cracked to flush out the carbon monoxide.
Knowing who did the welding, it doesn't surprise me.
Not really sure how it was done, guessing about 5 years ago.
Old 01-31-2019, 11:44 AM
01ssreda4's Avatar
you gonna reweld it?
Old 01-31-2019, 11:48 AM
Game ova's Avatar
I don't have a machine, going to have to farm it out.
Old 01-31-2019, 01:41 PM
Kfxguy's Avatar
Too bad i'm not closer, i'd weld it for you. I'm not the best, but i'm getting better and my **** holds.
Old 01-31-2019, 01:51 PM
Game ova's Avatar
Thanks man. Going to mock it up tonight, top part back on the head, and v band the bottom end back together and mark it as best I can so that it fits like it should when I get it re welded tomorrow. That's the part that scares me..... it not fitting right after the weld.
Old 01-31-2019, 03:43 PM
LilJayV10's Avatar
how much weight is hanging off the manifold?
Old 01-31-2019, 03:58 PM
Game ova's Avatar
Whatever the turbo weighs, divided by two (between the two manifolds). Not very much I'd say. (On3 7875)
Old 01-31-2019, 05:58 PM
01ssreda4's Avatar
i think they weigh 25 ish
Old 02-01-2019, 06:25 AM
Ron_Stoppable's Avatar
had the same exact thing happen to me a few years ago. Don't let anyone weld it unless they are forsure going to backpurge it. If fitment scares you, you could always add in a flex coupler in the crossover (Not the bellowed kind) to give you a little wiggle room.
Old 02-01-2019, 09:09 AM
The BallSS's Avatar
At least its winter so you'll have plenty of time to get fixed for race season.
Old 02-01-2019, 09:19 AM
Game ova's Avatar
Going to go to a local speed shop (dynosty) here in a bit, will have them do as you mentioned, providing they aren't retarded expensive (and can get it done today). In general they are a very expensive shop.
I MIGHT make one more hit when the track opens, while the air is still good just to see if I can get a single digit slip, if it will do it, I probably won't ever track the car again.
Old 02-07-2019, 09:32 AM
Game ova's Avatar
Finally got around to taking it to get welded. Was told it would be $250 , promptly replied "nah, I'm good.... thanks". Call me cheap, but imo that's retarded high. So the search for a reasonable quote continues.
Old 02-07-2019, 09:47 AM
Kfxguy's Avatar
Dude for that price you could spend a little more and buy your own damn mig welder and learn to weld. I don’t like relying on other people anyways. So you know what I’d do......
Old 02-07-2019, 09:58 AM
Game ova's Avatar
I can dig what you're saying, and I agree wholeheartedly. I also hate farming stuff out, which is why I do everything in house, motor/transmission and whatever else mechanical. Only issue I have with buying a welder is, I can count on one finger the last time I've needed one in the past 10 years. If I was always changing cars, and doing a lot of fab work, then I would. But as it is right now, I just can't justify the cost.
Old 02-07-2019, 10:46 AM
cam
cam's Avatar
