Mavns new Turbski Build . (Replacing the 416ci motor)Turbo Kit is On!
#44
Got 80% of the bugs worked out.. 12# 12*… on 93 oct. Super easy timing and super rich tune up. Still rolls the **** out lol The car does not have a fuel system in it yet. Just a wally 450 pump dropped in. The trans likes to shift 50% of the time from 1-2 lol It needs a rebuild, has a lot of metal in the pan. but were going to Send it until its completely loses 2nd hah
#52
I don’t want to give an wrong info. But before purchasing the boost controller I have, I researched as much as I could. True boost by gear (I’ll explain in a sec) was the absolute most important feature to me. My car is 99% street and mostly driven on regular tires. The one time the car started smoking the tires at 45mph while trying to leisurely pass another car in traffic, convinced me I needed to tame it down. So in my research I came to the conclusion that the g force doesn’t have boost by gear. Which I really wanted it to but it doesn’t. The other ones that do have it are more of a timed boost by gear feature. You have to figure out how long you stay in each gear and when you take off from a dead stop it starts count down. That’s not really how I wanted it to work. Great for a drag car. The controller I ended up with actually knows what gear your in. So say your autocrossing, when you shift up or down, it knows. On the display, I can display many different things and what gear I’m in is one of them. Throttle position, boost, max boost, afr, mph and rpm are a few other things it can display. I’m not trying to sway anyone against buying any of the available controllers, I just want you to be aware that if you want actual boost by gear like I did, you may need to do some emailing and asking questions. Make sure if you inquire that you ask if it will know if you down shifted. I’m sure all of the available units are not a bad choice, just research to make sure it’ll do what you want. Who likes buying something, thinking that it’s going to perform a certain function and then it doesn’t? Then you have to sell it and try something else. Not me! The only complaint I have about mine is the display isn’t as “elegant” as I’d like. It’s bare bones. Two toggle buttons and a segmented led numerical display. But, they are working on a lcd display with more features.
#53
