milled/ported 243's (59cc) or stock 853's for boost
Unfortunately blew my NA motor and have decided to go the budget turbo route for my 2000 ss. I'll be running a 5.3l and a 80-90mm turbo with ~15lbs of boost w/ the stock 5.3l dished pistons. Using the 243's would put my CR ~9.7 which is not alarming for boost applications, but I'm concerned that using these heads under boost will be prone to pushing water due to having a thinner deck The alternative would be to use my stock 853 castings (no notch) or POTENTIALLY trading the heads for something that better fits my application. Thoughts?
-Beau
-Beau
that's really what i wanted to hear. any opposing opinions out there or should i just stud the 243's, get an efficient turbo, keep timing conservative, and keep it below 20lbs?
