High horsepower turbo or procharged guys running single cat?
Ive been running catless on my procharged trans am now for a little over a year through a long tube headered/magnaflow 3" exhaust. The car makes between 650-700rwhp. Im looking to add a single cat in the I pipe to reduce the rasp and clean up the smell of the exhaust.
The 3 options im thinking of are
1. Kooks green cat ge-90140
2. MBS high flow 50 cell cat
3. Vibrant performance cat 7830
Anyone have experience with a high horsepower car and a single cat?
I have a 24" power stick muffler sitting in the garage i was thinking to throw on there but still looking at options. While the car isnt that bad with fumes, its enough to notice. My car is wideband tuned and im targeting an AFR of about 14.2 on idle. Slightly lower then stoich to account for the 10% ethanol in the 93 pump gas. What are your thoughts on the tune?
I had the same issue. Years of smell & years of reputable tuners trying to help (at least three with no such luck).
I simply lived with it. It got to the point that my wife wouldn't get in the car (of course I told her I would miss her ).
Ultimately I was able to get a hold of a set of Kooks greens & I gave it a shot. NO SMELL. Happy as a pig in ****.
My wife still wont get in the car ... something about going sideways in second/third gear. Apparently that's frowned upon in her world.
Note: I suffered no power loss BUT I have a TD system with two cats. Pushing all that power through a single pipe would leave me to believe you will lose some power. Yes it will reduce rasp but if that is the main concern there are plenty other ways to get it done as mentioned above.
Any exhaust fuel smell means you will burn up a cat. The unburned fuel will light off in the catalytic converter and melt it. Either clean up the tune or live with it. That being said, you will note that no factory engines make high horsepower through a single cat. Many of the N/A ones use 4 cats. This is mostly due to emissions requirements, but still...
