Cracked exhaust manifold lead to this......
So probably 5-6 months ago, I ended up cracking the passenger side manifold, then as I was fighting it on the reinstall....I cracked the driver side as well, only in my world does this happen. Decided to pull the motor and v band the driver side manifold where it cracked, I noticed that the intake valves were caked with burned oil....pulled the heads. Cylinder walls look fine, nothing really catches the eye. Any opinions as to what would cause this on ALL 8 holes? I thought maybe guides, but tough to believe that they are ALL bad, same with the rings. Thoughts? Oh, and this is with the car on E85.
Forgot to mention that, theres a very light film in the compressor housing, but doesn't seem to be enough to freak out over. As it is, I'm just venting to atmosphere.
Doubt it, looked a lot like it did 3 years ago when I freshened it up, only now the valves seem really caked up. Also changed turbos since... and no smoke out the exhaust that I can see.
Ding ding ding.
Ding ding ding, never thought to check till you guys mentioned it, so I went out and checked..... sure enough, oil in the charge pipe. This is straight off the intercooler exit.
Ding ding ding.
Originally Posted by Game ova
Doubt it, looked a lot like it did 3 years ago when I freshened it up, only now the valves seem really caked up. Also changed turbos since... and no smoke out the exhaust that I can see.Ding ding ding.Ding ding ding, never thought to check till you guys mentioned it, so I went out and checked..... sure enough, oil in the charge pipe. This is straight off the intercooler exit.
Yea, till now, i've been resistant to the catch can deal, but it's looking like this motor is going to need one. Doubt it is the turbo, as it's been looking like this through a few different units.
Oil in charge pipe caused by PCV? How much crankcase pressure is required to push that much oil through rings or valve seals into the induction system? How big are your crankcase vents?
If you are already venting to atmosphere a catch can isn't magically going to alleviate any more crankcase pressure then open valve cover vents. I've seen people run a recirculated catch can and keep blowing seals out, the sealed catch can only added crankcase pressure as it has no way to relive it under boost.
Generally helps to post more details then claiming "wrong". Without facts you cant prove you are alleviating more crankcase pressure then open vents.
Assume you aren't running open turbo, so you have a restriction on your turbo so you can suck oil into your engine? Doesn't seem like best case scenario.
How much boost are you running and how much did you decrease crankcase pressure with this setup? What size lines are you using?
I originally had mine just vented with 2 breathers on the valve covers but at the end of a pull I noticed a lot of smoke so I switched I bought 2 catch cans and routed one to turbo and one to intake both with check valves. Not saying vented won't work but my runs clean now with no smoke or anything. I'm not running a ton of boost only 15-22lbs and never less than 12lbs.
This I can say for sure, will be adding some type of suction to depressurize the crankcase. My heads/valves are absolutely putrid, the car will probably pick up 1/2 a second and 5mph with a fresh top end..... yes..... the heads look that bad. Being that I'm probably going to replace the springs while I have it apart, as cheap as the ported Katechs are, i may just throw a set of them on.
