Turbo in front rad in back...meziere Water pump help. I have a .250 motor plate with a stock corvette water pump that was milled .250 to keep belt line same.I recently moved rad to back under trunk and was wanting to switch to a meziere MEZWP319 to pump more water at lower rpm.The meziere would allow me to run same belt routine plus my AN hose should match up to inlet outlet.Question is the meziere bell were the belt wraps big enough that i wouldnt need to mill it? Is there enough material to mill it if i had to? Trying to find pics of water pump installed on corvette belt line to c if there is ebough left on the bell to move belt in .250?Thanks |
© 2024 MH Sub I, LLC dba Internet Brands
