LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Single turbo o2 sensor setup (https://ls1tech.com/forums/forced-induction/1919991-single-turbo-o2-sensor-setup.html)
The0nlyon3 05-12-2019 10:46 PM
I have a 5.3 with a single turbo. I’m running the Hooker Turbo LS manifold set with crossover pipe. Anyone familiar with the passenger side manifold, there is a 3” vband flange. That feeds my turbo. From the turbo I’m running a 3” downpipe. About 20” down the pipe is the o2 sensor. I’m running one... I’m also running a SD tune. Does this sound about right or normal? I’m worried about running an O2 right off the manifold pre turbo..
any input put would be great.
jayyyw 05-13-2019 07:31 AM
I have my o2s plumbed pre-turbo. I've seen a lot of setups like that but have also heard that you can cook them and they should be placed into the downpipe.
rotary1307cc 05-13-2019 08:19 AM
Pressure skews the wideband feedback, not a small amount. Leave it where it is
ddnspider 05-13-2019 09:00 AM
stock narrow band O2's in each header, wideband sensor in the downpipe at least 1ft away from the turbine outlet. No issues.
The0nlyon3 05-13-2019 09:45 AM
https://cimg9.ibsrv.net/gimg/ls1tech...dc350c0f3.jpeg
This is the turbo piping I’m running. I could throw one in the cross over pipe to read the driver side bank but on the passenger side due to it being cast iron.. and the D side feeds into the P side manifold and the merge at the front
Kfxguy 05-13-2019 09:53 AM
same here
jordoza 05-13-2019 02:02 PM
I ran a narrow band in each manifold pre turbo and my wideband about 12 inchs behind the turbo. No failures for 40,000 miles. I replaced the narrow bands awhile back thinking the pressure would have harmed them but the new ones didnt read any different at all. So in my experience pre turbo doesnt hurt a narrowband.
RonSSNova 05-13-2019 03:03 PM
If you are running open loop, you are fine.
I’m assuming you aren’t trying to run closed loop with the factory O2 sensors.
Ron
The0nlyon3 05-14-2019 02:30 AM
Ron
Closed loop would help with non WOT drivability correct? I need to relocate the factory narrow band pre turbo it sounds like
Lsxford 05-14-2019 08:21 AM
Ive been running 1 single narrowband in my downpipe. It is wired to both sensor inputs to the pcm. Works perfect imo the closed loop fueling stays between 14.6-15.0 back and forth.
I figure I tuned it off 1 sensor in the downpipe so why not have the narrow band there too. And I only had to buy 1 sensor lol
And it will 100% help part throttle. Maybe some of the great tuners can make a VE table that's close enough year round and leave it open loop. But I just stick a narrowband in and let the pcm do it's thing
The0nlyon3 05-16-2019 11:52 AM
Copy that, I did not know you could wire 2 into one sensor. Makes sense! Thanks guys for the input!! I’m going to go that route (wiring 2 into 1) and the relocate the narrow band into the pre turbo pipe for a more accurate reading. And leave my wideband in the down pipe.
Lsxford 05-16-2019 12:34 PM
Supposedly pre turbo pressure will skew the o2 sensor readings. Most advise against putting them there. But I have seen guys that put their wideband pre turbo and tune like that, but then again I read wideband isn't as affected by pressure as narrowbands.
I put mine in the downpipe because of the pressure skewing. There are several threads talking about the narrowband vs pressure thing. I never put mine pre turbo so I can't comment on that
© 2024 MH Sub I, LLC dba Internet Brands
