Tube front/ flex fuel rear mount radiator GTO build vsr88/348
#62
Interested in what you're doing with the pre-injector.
#63
Im going to spray a small amount of e85 on the compressor wheel, I’m going to do a little testing and see how much it drops my IAT. Probably start spraying around 8# or so, use the gold box to control it. If the e85 doesn’t do much I’ll put a couple gallon surge tank up front and use boost pressure to pressurize it, and use m1. If needed
powder coated my pro flo today, looks gangster!
The following users liked this post:
Marble_Sharp (09-22-2019)
#67
Yessir, that’s what I’m doing. Done correctly it should be vaporized when leaning the turbo, and if kept under a certain A/F ratio it isn’t really explosive. So, I’m theory it shouldn’t ever see any liquid e85. I’ll have to see what’s up. Many people do it with M1, and as I stated above it’s really no different than the countless setups running draw through out there, or spraying nitrous right after the turbo etc. I’m considering adding a burst panel to the charge pipe though, for safety.
#68
The vapor is more flammable than the liquid. All I can say is, you must carry around a huge pair of nutz. Because there’s so much that could go wrong there that I wouldn’t even consider it myself.
#69
Its just something ive been interested in for a long time. Pre compressor cooling is pretty impressive normally. I’d like to try it. Coupled with the fact that it will be set to be off below say 8# or so, if it blows off a charge pipe it will cut off instantly as there won’t be any boost on the map sensor. The few people I’ve spoke with on the subject all told me the same thing, that if you keep the amount of fuel in the air down that an explosion is not going to be able to happen. Honestly I’m wayyyyyy more sketched out by a simple nitrous kit than I am what I’m doing.
#70
I guess spraying 2-3 gallons of M1 into the inlet of a 14-71 blower coupled with 50# of boost changes your perspective a little. Back before we could afford intakes with burst panels we banged the blowers hard enough to rip them off the intake, but there was no fireball from the top side of the blower.
Well not trying to undermind you, but I wish you luck. Chances are you may never have an issue. It would just make me nervous. That’s why I chose to just use washer fluid. Maybe that’s flammable too? I know you can still ignite gasoline on water but I’m not sure about methanol in water. Maybe I’m being nervous for you for nothing.
#71
#73
Chassis shop called, started on my mini tubs and said my 4 link brackets have to go in their current location. So, in order to move them inward I have to hack up the car and run no backseat, I really want to keep my back seat. So, considering going to an fbodys type suspension with the tq arm to keep from having to do that. Fbodys hook good, and I’m familiar with it. Soooo, why not?
#74
Well we got flooded. Bad. 9” of rain in a few hours, local tows, hospitals, everywhere underwater. Shop where the car is at is flooded, my cars up on the lift, so it’s okay but the shop is suffering from alor of water damage. Hopefully they come out okay.
