So I finally got around to pulling the heads apart......
Car has been down for what seems like an eternity, for what amounts to a very minor issue (cracked manifolds). Until now, I've had zero interest in the car, figured id get out and turn a wrench or two... namely on the heads. Pulled the valves, and what I'm seeing makes my stomach turn, in fact I'm amazed the car ran what it did at the track. Car may well go high 8s with some new valves, and the crankcase issue fixed, jk.......well.....kinda. it really might do it. These valves are absolutely disgusting.
Most junkyard stuff I get looks about like that as do most 100k+ mile LS’s I work on. Sometimes when replacing springs I’ll clean them off but really haven't seen much change one way or the other. I just make sure the valve seats seal and sometimes have to buzz them with some lapping compound.
That's alot of buildup on the backside of the valve is oil getting past the seals/guides?
i forget of you mentioned it, but what kinda pcv and catch can set up are you using?
i ended up running dual cans, one for off boost operation and on for boost and that sucker needed to be like 3/4 hose to relieve the crankcase pressure and quit pushing oil everywhere
Atmosphere only. Will definitely do things differently upon reinstall. Every runner is caked with oil, may even order some Katechs, can get a complete set of ported heads fairly cheap. Will spend about half that if I just put new springs on my heads.
Oil getting into intake is either bad drain or its junk. Just chased this on an old garrett, turbo was leaking into cold side no matter what. I replaced the turbo since I was upgrading anyways and no more problems.
