Twin s372
Old Sep 29, 2019 | 10:32 PM
02 z/28's Avatar
Default Twin s372
Looking at switching up my turbo set up. I'm running a gt55-94 but looking at twins. Looking for faster spool and more power. Anyone running twin s372?
Old Oct 3, 2019 | 11:17 AM
svslow's Avatar
How much power are you making now?
Old Oct 3, 2019 | 02:20 PM
jordoza's Avatar
Twin s372 will never make the power a gt5t 94mm will. Of you maxed out a 94mm youd probably want twin s476 87mm turbine. Or that is my opinion.
You could always compound a 6766 on your existing 94mm and have the best of both worlds.
02 z/28's Avatar
1280hp
Old Oct 3, 2019 | 02:23 PM
02 z/28's Avatar
I ordered them, I was told they are good for 1500hp to the tire
Old Oct 3, 2019 | 02:25 PM
jordoza's Avatar
They might do that. Depends on the engine and a few other things.
Old Oct 3, 2019 | 02:28 PM
02 z/28's Avatar
Fingers crossed lol
jordoza's Avatar
Power gain from 1280 is different then power gain from a maxxed 94mm. I should have waited for you to answer about what hp you where at.
Old Oct 3, 2019 | 02:29 PM
SLOW SEDAN's Avatar
^ that... whats the setup at now? GT55-92 is rated ~200lb/min, S372's are rated at ~110lb/min each. The potential for more power is there, but not a ton. If your built to take GT55-94 power I would be looking at twin 75 or 76's to really mash out.
Old Oct 3, 2019 | 02:33 PM
SLOW SEDAN's Avatar
Originally Posted by 02 z/28
1280hp
Your GT55 should make 1500! That's an 1800+hp turbo, unless you have like an V1 cast joint. Hard to compare so many different versions of turbos these days.
Old Oct 3, 2019 | 04:09 PM
jordoza's Avatar
Thats what i was gettiij ng at that 94 should have more in it. The s372 are a step up from his current hp but not a step up from that 94mm maxed out.
Old Oct 4, 2019 | 07:45 AM
transam69230's Avatar
Running s374s from Workturbo on a 402 Dart LS Next, and maxed out I am making 1600rwhp.
Old Oct 8, 2019 | 10:21 PM
brbntrl's Avatar
Whats your psi maxed out?
Old Oct 10, 2019 | 07:40 AM
The tuner is going off of compressor wheel speed and back pressure data, but its between 35-38 psi.
