Cylinder Head Help
put a PD blower on it and be done if you want a flat curve
A strong 7500rpm on an LS6 intake is probably doable, but also not the ideal choice. An aftermarket shorter runner intake would make more sense, ProFlo or something.
And camshaft/valvetrain need to be suitable too. 690 lift springs seems a tad odd for a relatively mild motor and mysterious camshaft. In fact...seems just wrong.
But heads...what is your budget ? there are any number of heads these days.
the cam is a comp 54-481-11 and comp rocker arms with a trunnion upgrade comp 26526 spring kit
Nothing fancy, but after a little google action it appears that this would not be an RPM limiting piece, at least not at the RPM I am going for
My opinion like doug said get a more bigga turbo.
However, for your manual setup, I'd think you would need a cam that delivers low-end and let a better turbo carry the boost past the cam redline to do its work up there. Could you also use a better rear gear for off the line performance?
I ran a 7868 turbo and hit the wall at 5800, switched to a 7875 and now makes power to 6600 and trending up so probably to 7K at least.
Gears actually hurt performance on a turbo car as it provides less load to get the turbo going.
