Subeone's Boosted SS project Whats up guys, Just bought an 01 BLK SS with 60,000 miles! Ive always wanted one but every single one I would see was just clapped out. The car was originally from Alaska, and has some nice parts! it already has an M9 rear th400 with brake ptc converter (ima throw in a 9.5 17-0 stator that i have laying around) 10 point chromoly cage Some kirkeys Beadlock weld s71s https://cimg8.ibsrv.net/gimg/ls1tech...eb288cf04c.jpg The car is still on the ls1 (ms3 cam, bolt ons, and a nitrous kit) but I already have the power plant ready to go in. https://cimg9.ibsrv.net/gimg/ls1tech...d1cf28fd8d.jpg This is the day that I got the car. Got the guys at Ricks Machine shop here in Houston putting my 370 together. I am using CP bullet pistons China EPW rods Factory GM crank main studs Still undecided on the heads, I have some worked LSA heads laying around somewhere so I may stick those in with some ca625s. I also might buy some TFS 235s. Not sure yet. https://cimg1.ibsrv.net/gimg/ls1tech...1a60375d0.jpeg https://cimg7.ibsrv.net/gimg/ls1tech...58bf985f5.jpeg LSA head, bowl. Done by shawn hooper out of houston TX https://cimg0.ibsrv.net/gimg/ls1tech...93d5ca3c1.jpeg I purchased a twin turbo v3 kit from huron yesterday too with the bumper exit so cant wait for that to come in. I got several turbos laying around but recently found these s369s so probably going to run those. Seem to be regular out of the box sxe borgs. https://cimg8.ibsrv.net/gimg/ls1tech...4c604eb4ae.jpg For the intake manifold I bought a rectangle port btr equalizer a month or 2 ago so I plan on running that. The thing looks ugly as fuck but its the only decent one that I can see that will clear the cowl, kinda contemplating buying a plazmaman billet intake tho. Or just wait til TSP releases their billet unit. We will see. I got 2 precision gates that i had planned to use on my foxbody, but ill use those on this thing. Twin 44mm gates. I have some BOVs too, covid 19 ones lol. For tuning I will run either holley HP or a terminator X, i have 2 systems somewhere in my garage so I will see which one fits my goals. I will be piggybacking the factory ecu as well so all factory gauges work like stock like in my silverado 😁 Ill be running coolant pressure, ill have an onboard compressor from viair with dual macs, backpressure sensor for all the data, and probably compressor wheel speed sensors. (Ill replace oil pressure input and configure for backpressure for those asking how i will run so many inputs). I have a ton of lowdoller sensors so im set there. Intercooler will be the chy-na 3.5" huron uses. i think the only thing this car is missing is a battery relocation, and a fuel system for now. Ill be using dual 525 walbros probably with some 210s and a fore innovations fi2 regulator, and fi2 controller that i have from when i removed off my silverado. I hope to run 5.0s or faster when I am done with it. Not sure how much power i will need, but im confident ill get to 1100 safely with this combination. |
Awesome. Look forward to the build. |
Don't see many non-lsa cars/motors with LSA heads. In for the build! |
Maybe check out the Shearer Fab Holley intake he does? Should clear the cowl, looks badass, performs well and will set you apart at the cruise in too. ; ) |
Alaska cars are crazy clean, aren't they ? / |
Looking forward to this build Subscribed |
Are you having the mains line honed? I really need to get a holley terminator. I'm getting sick of the factory computer limitations |
Oh Man Cesar made a Build thread SUBBED!!!! |
what up Cesar! they finally lock texas down and now you have to be on the internet? lol |
https://cimg8.ibsrv.net/gimg/ls1tech...603b40df2.jpeg What do we have here 🤔 And yea it was align honed, wasnt off by much however. Lol man im as busy as ever but itll be nice to look back how this car progressed and ls1tech would be a place to document it all have a link to the shearer fab unit? So after seeing how much of a shit show it was to run triple pumps on Mavns SOM, I have decided to stay with a dual pump setup. After some careful thinking, and some self motovation to not run a fuel cell, I decided I will experiment and try a new pump setup. I plan on running dual 295 series pumps. They are essentially a 535 LPH variant of the 450 LPH. https://cimg7.ibsrv.net/gimg/ls1tech...7a64096d91.jpg Courtesy of Radium The 295 variant flows almost 100 liters more at 70 psi (target fuel pressure at 30 psi of boost). An extra 200 lph will be almost equivalent to having 2 450 walbros and an extra 255 gss342 without the complicated wiring mess or the extra current draw. Not to mention the shit show in the fuel pump hanger. Another pro of going this route is the current draw. https://cimg2.ibsrv.net/gimg/ls1tech...e5f9bade91.jpg Courtesy of Radium. The 295 variant slightly edges the 274 (450lph) variant by an amp or 2 at 70 psi, and over 3 compared to the 285 (525) variant. This is always critical in an fbody with 2 ecus, a sound system, & derale pusher fans (these fuckers draw so much when they turn on lol). There is however a drawback 😂. All of this is possible because the 295 pump does not have a check valve. Flow is improved and of course the restriction is reduced, hence the lower amperage draw. For people trying to stage pumps, it will be impossible to run a setup like this. I plan on running both pumps at all times, and priming wont be a problem as i wont be limited by the 1 second prime timer offered by the factory ecu. With holley i can set the prime time to whatever I wish. Lets hope this setup works however. |
I run two 450's hot all the time. -8 feed, -6 return, china regulator, no issues whatsoever. staging them is a pain in the ass |
(Post 20229901)
That thing is gonna fly. I’d be happy to drive for ya. 😁 |
Cool build, your not going to want to race trucks after its finished, lol....you dont know what a pain is until you put triple pumps in a Z06 tank!! |
cant wait to see this build progress! |
Looks great! Curious to see how the fuel pump deal works out. I have a fox mustang so my set up is obviously different but I bought it built and have since changed almost everything. It came with the On3 tripple hat and 3 of their 340/320 pumps. I made 850 rwhp with them but with the new Dart 388 and 91/102 they concerned me. I was planning on replacing the 340's with the HP 450's but came across a deal I couldn't pass up on 3 new 525/470 pumps. I am just finishing up the swap and so far so good but that is basically idle and putting around town. They are wired up with 2 on at all times and the 3rd comes on via boost and tps from the Holley. |
So once i get the engine back ill have ryan (badass68) come to the shop and do the 1/2" stud conversion for the block. I decided to splurge and buy the PRC 6 bolt as cast 250cc. I also got a free cam! They decided to sponsor me a bit with other stuff too I'll show you guys once its here. I am also currently building my foxbody, puttin a 88/103 on it simultaneously as I build this camaro.. Corona got me doing silly things lol. i maxed out 3 450s at 1400 on my truck, 525s should get you close to 1600 so youll be fine! |
Originally Posted by subeone
(Post 20232748)
Very nice Subeone. F-Body resurrection at HPF |
very nice! In for updates. |
| All times are GMT -5. The time now is 04:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
