ECU's with boost in mind for 2020
I've been planning out my LQ4 turbo build for a bit. It's sort of on track and not all that serious yet. Mainly my big block died and I decided to do another LS swap but this time add boost.
It's going into a 1964 C10 and I plan on running a T56 magnum to keep it interesting. I'm considering an S480 or possibly twins.. still needing to read more for what may be better for a daily driven manual transmission truck.
Anyway, I'm, looking at ECU's. I'm not using the stock computer for this. I've done that on another build and I just don't want to again. I've been looking at Holley Terminator X for this swap, but today I came across a 1000HP + corvette video that said it ran ProEFI 128. What the heck is that?! It has some interesting specs, multiple boost control levels, on the fly fuel sensing / changing, and some nice looking traction control (i want this for the 64 to help keep it out of the ditch with boost). I can't seem to find much on Pro EFI, and I did find some quite negative feedback from about 3-5 years ago. Does anyone have experience with this? I'm not going all out, but if there is something better than the holley for like money, let me know.
Alex
Personally I would use Holley or MS3. FuelTech is also impressive stuff and I really like their dash.
the higher end holley and MS3 stuff really isnt that much more money and its worth getting all the extra functionality from the beginning. i currently have a terminator x in my swap car and i fully intend to replace it with a dominator a little later on in the project. it runs and drives great, started fine, etc. its a great ecm. but the second you want to start expanding capabilities, youre out of extra IO, plus theres a bunch of little things holley left out that they dont exactly tell you about. the two off the top of my head that added the most hassle for me is there are no VR inputs and the log software does not support math channels.
the pro-efi stuff is pretty high end, and they offer a 'plug and play' type setup for a c6 that claims to be compatible with the rest of the car's CAN and controls, so everything still works as it should. that really isnt a concern for your build.
So I would say the terminator is perfect for nearly everyone except very few.
I would use the terminator in MOST swaps... then there are those particular situations it just doesn’t “fit” the build.
MS3Pro Evo supports native VR inputs, so you can use ABS sensors for speed/traction control. The datalogging software is also far better than Holley.
There are probably a dozen other aftermarket EFI options out there that will work, but I don't think I'd be impressed by the ProEFI for the sole reason that a twin turbo 427 made 1000 HP with it.
Andrew
Andrew
Don't get me wrong I like the Holley line. It's user friendly and well laid out. And if you dont' want all the additional inputs and outputs and a hand held tuner is what your after by all means, go for it. Seems to be a quality product anyway. Just not as many features for your money.
I wouldn't confuse FItech and Fuel Tech either as they are on different ends of the planet!
Andrew
Its not like any of them are limited on the power you can make, they all have the same logic and safeties, so I'm just curious what you are selling people on.
- MS3 has 10 injector and 10 ignition drivers instead of 8. (you can use the additional drivers to PWM control things like boost control, water injection, fans, extra injectors, etc.
- 6 outputs vs Holleys 4
- 7 inputs vs Holleys 4
- Built in USB and SD card (onboard datalogging)
- Software setup for nitrous, boost, water/meth, and traction control is already ready to go on the MS3.
- Then you have the option of CANBUS and a micro squirt for $300. That can give trans control and/or an additional 7 inputs and 7 outputs. 4 wheel speed/VR inputs. While the The 8 channel CANBUS for the Holley is $325…
Just makes no sense to go with a Holley if you are interested in those features IMO
https://www.holley.com/products/fuel...x_max_ls_kits/
1.) The point is the MS3 comes with 2 additional fuel and spark drivers that the Holley does not. What you can batch fire or make work is besides the point?
2.) What does multiple mean for outputs and inputs? I'm stating facts. The total number Holley has VS the total number MS3 has. I'm looking at Holleys website. It says 4 inputs and 4 outputs for the HP and the Terminator.
3.) Looking at the website it specifically states "external data logging only"
4.) under traction control, and water/meth it states "no" .
