Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
Reload this Page >
Anyone ever relocated the radiator verticle on LT1 for more room for pulleys, etc?
Notices
Old 07-23-2004, 08:19 AM
Default Anyone ever relocated the radiator verticle on LT1 for more room for pulleys, etc?
I want to relocate the radiator verticle and up against the core support. I was going to fabricate the lower core support to hold a lowered plate to house the radiator (making it sit lower in the car). I will be having a custom radiator built to for correct specifications. I just want the room for COG pulleys, etc. Anyone attempt a project like this?
potentz is offline
Old 07-23-2004, 08:35 AM
1point3liter's Avatar
Hello and welcome to LS1Tech. jk
1point3liter is offline
Old 07-23-2004, 08:52 AM
What size cog pulleys are you using?. You should have more than enough room to run cogs on the car without haviing to relocate the radiator. You also might want to try asking this question at www.camaroz28.com Its a little more geared to the LTx platform.
MEAN LT1 is offline
Old 07-23-2004, 10:47 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
On my LS1, I have the factory radiator more upright. This was possible since I am no longer running a factory airbox setup. Once that was all removed, it created a lot more room. I could run a cog setup or a 12 rib setup if I wanted to. My fabricator just used some strips of aluminum for the top of the radiator.
Pro Stock John is offline
Old 07-23-2004, 12:47 PM
Thanks guys and awesome form!!! I have been a member of Camaroz28.com for years. I just really like this form as well and I find it more technical and helpful at times.
I also want to reloacte the radiator because I think it would really clean up the look of the engine and allow you to see the front of the engine and supercharger. I got rid of the AC, power steering and I am going to mount the alternator down low. So I think I could really make it look good.
Does anyone know if someone makes a alternator relocation bracket other than Madman?
Thanks
potentz is offline
Old 07-23-2004, 10:24 PM
pmbmax's Avatar
Default yes i have one
Thanks
I have one for sale i make them and can make you one are i will sale you the templit and size of spacers
pmbmax is offline
Old 07-24-2004, 09:16 PM
SJM Manufacturing Inc's Avatar
You can easily move the radiator forward as PSJ has stated. With the removal of your condensor, it will also allow additional clearance.
On another note, our company has been manufacturing LT1 alternator brackets for over 7 years. We use T6061 grade aluminum only and the kits are a direct bolt-on.
You can view them on our site located at:
www.mycamaroz28.homestead.com.
If you have additional questions or concerns feel free to e-mail us directly at [email protected]
Hope this helps,
Steve
SJM Manufacturing Inc is offline
Quick Reply: Anyone ever relocated the radiator verticle on LT1 for more room for pulleys, etc?
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
