LSA blower build
Old Nov 1, 2024 | 10:38 AM
Black_Sunshine_99's Avatar
Originally Posted by 1970hemicuda
I'm not opposed to changing them myself. I know I could do it. It was more on the fact it felt silly to buy brand new heads with aftermarket springs and then have to buy another set. I have a ton of more parts to buy so the $300 ish for new springs would be nice for other stuff.
This will be in a daily and the one or two times i would take it to the strip. I'm not gonna be spinning it past 6500 at all. The springs in the summit heads are pac dual springs so if people think I'll be okay with those and the .600 lift cam then I'll run it. I always go on the side of caution and overbuild so that's why I was concerned.
Perhaps a custom cam with lower lift would be a good compromise?
For a daily and reliability, I'd prefer something with lower lift and soft lobes to extend valve spring life.
Hit up Pat G., BTR, Baker Cams, etc.
I'm sure they can recommend something that will fit since you're buying a cam anyways.
Old Nov 1, 2024 | 10:45 AM
Mr. Black's Avatar
Speaking from experience with the LSA blower you are going to be below 4k RPMs nearly all the time. I probably spend most of my time between 1500 and 3k rpms lol. Hardly a harsh valvetrain environment.
Old Nov 1, 2024 | 11:52 AM
Project GatTagO's Avatar
Checked out those ebay cylinder heads and they look good. Would have to change valve springs too on those. I took a look at AFR heads and they are nice as well, but again only use .600 lift springs. I know it's not a huge deal but just annoying if I'm buying brand new assembled heads, I'd have to change out the springs. Seems like no one offers them with .650 springs, atleast in the "budget category". Not looking to spend $1800 on cylinder heads.
I may wait till black Friday deals roll around and see if i can save. Really want to run the ghost cam and don't feel comfortable running a .600 of lift on .600 springs. Seems like a bad idea, unless it's fine?
Perhaps @Summitracing can answer this question?
Andrew
Old Nov 1, 2024 | 11:58 AM
Diesel powerband lol.
I'd be making that LSA blower make that glorious whine all the time.
Old Nov 1, 2024 | 12:53 PM
Summitracing's Avatar
LS1Tech Sponsor
Thank you for tagging us, @Project GatTagO.
OP,
Our private brand team is reviewing the details regarding the heads and springs. We will provide an update next week. We'll come back with some cam options at the same time.
Stay tuned
__________________
800-230-3030
www.SummitRacing.com
Old Nov 5, 2024 | 06:27 AM
1970hemicuda's Avatar
Well I picked up a set of 823 heads with rockers for $300. It was 10 minutes away from me so couldn't help it. I'll be building these up and running the BTR .660 springs.
Old Nov 5, 2024 | 06:41 PM
Mr. Black's Avatar
Dude, that is the steal of the century!! Especially if they don't need any machine work.
Old Nov 5, 2024 | 07:55 PM
68Formula's Avatar
Jeep has a tremec TKX in it so I'm limited to 600hp.
Actually you're limited to 600ft-lbs of torque. It's torque that kills transmissions, not hp. Make all the hp you want, just make sure the resulting calculated torque value doesn't exceed the transmission spec.
Old Nov 6, 2024 | 10:12 AM
Heads are in really good shape but I wouldn't feel right if I didn't send them to my machine shop for some cleanup work.
What brand lifters are people using? Seems like every single one has mixed reviews nowadays
Old Nov 6, 2024 | 11:28 AM
Genuine GM LS7 or Johnson lifters.
Old Nov 6, 2024 | 11:40 AM
Jimbo1367's Avatar
Originally Posted by ryeguy2006a
I agree, you don't need a huge cam to make really good power. I built a stock 6.2 L92, stock 823 heads, Summit 8715 stage 1 ghost cam, stock CTSV lower balancer, and 2.5 upper pulley. I was also on 1 3/4" shorty headers, but it made about 11 psi on that combo. The rest was stock and I made 633 whp and 619 tq. Made 500 wtq at 3k rpm's and like Andrew said, that combo just ripped.
you forgot about home porting the blower snout. I’m betting this helped too
Old Nov 6, 2024 | 02:52 PM
  #32
kinglt-1's Avatar
My dad's 5th gen SS A6 recently made 632whp with a LSA swap @ 8psi, BTR red hot cam, headers, E60 fuel.
Old Nov 20, 2024 | 06:42 AM
  #33
LS1Tech Sponsor
Hey Folks,
Sorry for the delayed reply. We see the OP scored a good deal on a set of 823 heads but we wanted to update the community on the springs on our heads. Our Private Brand team pulled a set of SUM-162LS3255REC Precision Cast LS heads off the shelf and inspected the springs. The heads have a 1.800" installed height and the springs coil bind at 1.070". We are calling .660" the max lift number (.070" out of coil bind) in case someone has a rocker with a slight overage in ratio tolerance (very common). We confirmed the three cathedral port heads SUM-162LS210CATH, SUM-LS210CATH64,and SUM-LS210CATH60 all have the same .660" lift springs. Our website will be updated to show .660" is the max lift for the springs.
__________________
800-230-3030
Old Jan 2, 2025 | 10:39 AM
  #34
Getting ready to get the heads redone and I would like to get new valves. Are the factory LSA valves a good choice? Rockauto has them pretty cheap.
Old Jan 2, 2025 | 10:49 AM
  #35
Mr. Black's Avatar
What makes you think they're bad?
Stock GM valves are very reliable for 100s of thousands of miles.
The only time I've seen them damaged is from physical damage or when heads have sat open with water getting in the ports.
Definitely other things to spend money on IMO.
Old Jan 2, 2025 | 11:23 AM
  #36
They have some surface rust from sitting and I just thought it was cheap insurance to get all new parts.
Old Jan 22, 2025 | 11:52 AM
  #37
Anybody run this belt drive setup or have any input on it? Can't really find much info about it. I need to source a drive and the would rather get an upgraded style vs the OEM.
https://www.crossmembers.com/product...43815810072830
Old Jan 22, 2025 | 12:11 PM
  #38
What's the advantage over a stock set-up?
Andrew
Old Jan 22, 2025 | 01:39 PM
  #39
Andrew
For me it just makes it easier than buying all the OEM stuff separate, and cheaper I think too.
Old Jan 22, 2025 | 03:32 PM
  #40
Gotcha. I was just curious if it had any advantages over stock
Andrew
