new best 787/790 pump gas
peak boost was 20psi, ice in the intercooler
this is higher than its ever been rwhp ever for me, look forward to trying it out like this next event.
car pulled cean up through the revs thanks to a new set of gm perf. wires.. the morosos are going back for a refund!
thanks again to agostino racing for this strong a$$ motor and turbotechnology for the sweet a$$ turbo set up. thanks guys
Btw, I am gunning for ya...16 psi and 730/740
. 1st track trip (1st time on et streets) yielded 11.1@137 (with the pcm pulling out 4 degrees). I know I won't ever hit your times (stock Y-Body suspension).. Btw, thanks for all the help with the timing info and Snow kit info. peak boost was 20psi, ice in the intercooler
Is that through a cutout or exhaust? (and is the gate vented to atmosphere or routed in?)
What are you running for induction? (air filter)
Anyway I could convince you to measure turbine inlet pressure next time it's on the dyno?
A compression tester hose will thread right into one of the o2 bungs.
goober, good luck with your combo.
earl, you got better aero than me! glad everything is working well.
intimd8
its a 3.5" downpipe to a 4" intermediate pipe and 4" dynomax bullet then 4" turndown.
the w/g vents to atmosphere through its own baby exhaust pipe.. cant say that i hear it at all at wide open
the air filter is a cone k&n maybe 8" long behind the intercooler tank here
http://community.webshots.com/photo/...19999031QAkoJm
i havent measured that pressure before but ill keep it in mind next dyno, i do have an open bung there..and i would like to know as well.
dyno run vid http://home.comcast.net/~mightym0use/787dyno.wmv
if for any reason you are interested let me know ill cut you a good deal on this 80mm.. i may be switching things around
