LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Where's the power?? (https://ls1tech.com/forums/forced-induction/221057-wheres-power.html)
99fireredls1 Sep 28, 2004 12:08 AM
Where's the power??
What is going on here? I have a 1999 Ta with an ati blower m6 373 gears 6 rib set-up that I have had dyno tuned at 604rwhp and 570rwtq. Then I went to the track and everything went to hell. My best was 11.79
Here is the only slip I could find from the night
60' --- 1.696
330 --- 4.919
1/8 --- 7.681
mph --- 90.54
1000 --- 10.019
1/4 --- 11.999
mph --- 114.99
shifts were fast, not pro fast, but good strong shifts.
My question is where is all my power going?? belt slip maybe??
QuickSilver2002 Sep 28, 2004 12:57 AM
60' --- 1.696
330 --- 4.919
1/8 --- 7.681
mph --- 90.54
1000 --- 10.019
1/4 --- 11.999
mph --- 114.99
I would guess belt slip. The dyno and the track are worlds apart.
You need some way to log boost and A/F.
red90cobra Sep 28, 2004 01:20 AM
that's not right, your mph with that much hp is off big time
98Zam Sep 28, 2004 04:37 AM
How long ago did you dyno? do you have a boost gauge?
Unusual T/A Sep 28, 2004 08:48 AM
That is what a 344rwhp car should be running. Where did the other 300 go?
99fireredls1 Oct 2, 2004 01:43 PM
Sorry guys I was away from my computer for a few days. I just sent my pulley setup to SD Concepts. I am upgrading from stock 6 rib to their 8 rib setup with the steel plate. The guy at SD Concepts said it is either lotttts of belt slip or the belt is hopping when I shift. No belt hop on the dyno because I kept it in the same gear. I do have a boost gauge, but it does not record boost and kinda small to watch at the track. I went to the dyno about a week before taking it to the track. Anymore ideas please chime in. Thanks
MstgKillr Oct 2, 2004 04:45 PM
You will be happy with the SD Concepts stuff. Let us know when you hit the track again.
© 2026 MH Sub I, LLC dba Internet Brands
