GTO supercharger comparisons inside!
There are now three supercharger brands available for the GTO. Each one has it's own benefits so this info should be help you decide which one is right for you -
Vortech
The addition of the V-2 SQ S-Trim supercharger will increase horsepower from 350 to 481 and torque from 365 lb./ft. to 435 lb./ft. at 7-8 psig at the flywheel.***
The system includes an integrated dual-pass air/water charge cooling configuration, which features a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as billet aluminum mounting bracket, fuel system upgrade including replacement injectors, supercharger oil feed and drain, compressor bypass valve and all required fasteners are included. The installation allows retention of all factory accessories including A/C and power steering. This system is available in satin or polished finish. The V-2 supercharger is covered by a three-year limited warranty.
*Legal in California only for racing vehicles which may never be used upon a highway.**6-Speed system to be released by the end of September, 2004.***Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements.
ATI ProCharger
The new Intercooled ProCharger system for LS1-powered 2004 GTO’s produces a 50-55% power gain on stock motors running pump gas, with 7 psi of intercooled boost. This compares to competing systems which produce 29-37% horsepower gains with the same 7 psi, but without ATI's superior supercharger and intercooler technology.
This system installs in approximately half the time of other systems, with no need to punch a hole in the oil pan, replace the engine intake, or deal with all the complexity of an air-to-water-to-air intercooler. This new ProCharger system also has a much more attractive and "OEM" appearance than others for the GTO. Additionally, with the coolest charge air temperatures available, the HO Intercooled ProCharger system for the GTO produces not only the industry’s undisputed largest power gains, but also the best engine longevity.
Standard equipment includes an exclusive air-to-air intercooler system and a patented self-contained P-1SC-1 supercharger, with 3-year warranty available. This new product utilizes the same proven technology as the industry-leading Intercooled ProCharger systems for LS1 F-bodies and C5 Corvettes. In addition to the HO Intercooled system, a tuner kit and D-1SC serpentine race kit are also available. With modified LS1 motors, the D-1SC serpentine race kit is capable of supporting over 700 horsepower.
HO Intercooled System
7psi, 50-55% horsepower gain (5 psi pulley also available)
P-1SC-1 ProCharger, custom GTO specific air to air intercooler
100% complete with fuel injectors and handheld programmer
Dedicated 8 rib drive system with automatic belt tensioner
Tuner kit
Omits fuel injectors and programmer
Otherwise identical to the HO Intercooled System
D-1SC Serpentine Race Kit
D-1SC ProCharger intended for modified applications
8 rib drive system - requires the purchase of an aftermarket harmonic damper. ProCharger crank pulley is compatible with Fluiddamr part number 740102. This may also be compatible with other manufacturers
Otherwise the same as the Tuner kit
Magnuson
O.E.M. quality Mp112 5th Gen, "hybrid" roots style intercooled supercharger w/integral bypass valve
Intercooled application features a unique air to liquid heat exchanger that is integrated into the manifold, below the supercharger
Computer programmer - re-flashes factory ECU, spark and fuel control, transmission shift points, line pressures and torque converter strategies are optimized to manager increased torque, horsepower and mileage.
Two warranties - standard 3 year limited warranty or add an optional 36,000 mile 3 year powertrain warranty for $200.00
Does not void your warranty
100% complete with step-by-step instructions
This all-new intercooled supercharger system utilizes the Magna Charger MP112 supercharger with internal bypass valve. Torque and horsepower output is improved from 1500 rpm to 6500 rpm,
This kit is complete with all components necessary for installation. Included in the kit is the cast aluminum intake manifold and all necessary hardware to complete the entire installation. Other components in the system include new fuel injectors and extruded aluminum fuel rails, coolant circulation pump, intercooler core and heat exchanger. Factory push lock connectors are utilized in the fuel system for ease of installation.
ORDER LINE - 1-877-4-TBYRNE
SEND US E-MAIL
SUPERCHARGER DISCOUNTS AVAILABLE!
Vortech
ATI ProCharger
Tuner kit
Magnuson
SEND US E-MAIL
