I have a 99 firebird formula, and recently bought a d-1sc serpentine kit, 42 lb fuel injectors, and a holley fuel pump. Everything is stock on my car, just wondering how much boost i could run on it, what compression ratio is best and how to go about getting it there
7lbs is the upper limit of reliablity on the stock bottom end. based on the amount of miles on your car. People on the forum have run more, but when you burn twice as bright it is for half as long. If you have the intercoolers 8lb is absolutely the upper limit. For part throttle driving around town and cruising around under 2000 rpm, 14.7 is fine. You wont hurt anything. When you go into boost, 11.5 to 12.0 is a good place to be.
These are basic guidelines and should not be used as an exact science. I am not nor do I claim to be an expert on the LS1. I did design my engine, and feel that I can make the above statements based on experience my own experience with my own car.
